high CPU usage leads to little performance UPDATE: Definitley not a virus....Please Help
paralazarguer
Banned
Jun 22, 2002
1,887
As explained earlier, you probably didn't clear the MBR when you formatted. Follow the instructions that I posted above to properly clear the MBR. A simple reformat is not enough.
BHeemsoth
2,738
I formatted the whole system including the MBR and I am still having similar problems. The CPU usage is no longer around 100% but the performance is still unbelievably low.
Anyone have an idea?
bontu
182
are u sure you still cant see the processes running? it really sounds like some virus is running in the background. I had a Klez virus variant which infected my other pc. It really slowed down performance alot since it used up the CPU 100%. You couldnt even use NAV to detect it since the virus compromised the scanner already. It even tries spreading through the LAN making multiple copies of itself. It was pretty bad. The only way I could get rid of it was reformatting. But it sounds like you might have a possibly worse virus.
try downloading and running taskinfo2000 to see whats running.
my cpu usage is usually just 2%-4% idle running a whole bunch of instant messengers among other stuff.
maybe grab a screen shot of the processes running and post it so others can see.
Viper96720
4,390
They want you to low level format the drives write ones and zeros gets rid of everything on the drive. Why don't you compare your scores with other pcmark scores. What kind of raid setup is it? Raid-0 or raid-1 if using raid convert your disks to dynamic disks. Go to disk management and you should see your drives. Right click drive and convert. This will improve performance some.
Snoop
1,424
It would be helpful if you listed what type of motherboard you are using. If it is a Via, did you load the Via 4in1 drivers?
BHeemsoth
2,738
It is a Gigabyte GA-7VTXE + with a VIA chipset.
And yes i did load the 4 in 1 drivers.
MadRat
11,999
307
The memory is definitely a liability at PC2100. I have a feeling though its your 5v rail is just going out on that P/S.
MadRat
11,999
307
If I hadn't seen it before then it wouldn't make sense. The sad thing is it costs $20 for a new one to find out!
Dreadogg
1,780
take all your other pci cards out, then try again, if you got two sticks of ram try one at a time! Are you on a network? Reset your bios to default.
