Help with simple sound problem.
Martin
29,178
Hi, I need to record some stuff, but for some reason, sound recorder and other sound recording apps, record the line in and not the mic. I got win2k and SBLive value.
I remember that the mic worked at one point with sound recorder, but now it doesnt. The actual mic is ok, since when its plugged in, I can hear it on the speakers (unless I've muted it), but sound recorder records only the line in (currently connected to a VCR)
thanks for your help
also, I tried connecting the mic to the line in, but that didnt work either...
obenton
2,012
Check mixer settings. There are separate settings for recording and playback. You've likely got it muted for recording, but not muted for playback
