Help with possible upgrades
Why would it be trolling? There could be a better option that I don't know of and hasn't been brought up in this thread. I'm just open to anyone's ideas before I place the order for this one.
if you're still using a 7600gt, then I'd go to gtx 460 768 instead. they are a lot cheaper than the 1gb card but give you ~ 90% of the performance up to 1920x1080. the 1gb card is only necessary for real hard core gamers or those with enormous monitors. check in hot deals section, you should be able to get the 768mb card for ~ $110-120 or so. Plus, they're so easy to OC with afterburner, it's almost like cheating.
how about reading my whole post instead of picking a single sentence out?
I did and once again you blow the CPU is blown out of proportion instead of properly framing the situation for him. Outside of some very, very picky games, you really don't think there would be a difference between a GTX 460 and GTS 450? At his resolution in his system?
What is basically the step down from a GTX 460/HD6850? The GTS 450/HD5770. And that's a pretty big step down.
he has a freaking 7600gt at the moment so anything would be a massive upgrade. I said unless he was actually going to play newer games than CSS then there is no need for a $160 gpu.
of course the gtx460 would be faster than a gts450 at that high res and I never said it would not. though higher resolution doesn't magically make his stock E5200 handle cpu intensive games any better now does it? there is NOT one single thing wrong with what I said to him.
Oh man you should have gone with ATI! That would have been way better than that Nvidia card. J/K Enjoy the card, you are going to be amazed coming from a 7600gt.
At his resolution he should be getting a 1GB card. In fact the GTX460SE would be a good fit. They show nice gains from overclocking, are considerably faster than a 450 and 5770 (especially overclocked), have more VRAM than the 768MB-460 (I'm confident this will make a difference at his resolution and put the SE above the 768), and are cheaper than standard 6850s and 460s.
I never contested this.
No, you didn't really say that...
since the OP hardly games and when he does its mainly CSS... problem is some of those newer games might need a little more oomph than an E5200 can deliver.
In fact that statement is in complete contradiction (in tone) to what you wrote afterwards:
if he is really going to try and play some newer games then sure.
You were not very clear, at all. Your more aggressive stance with the statement "since the OP hardly games" overshadows everything else you said, as well as that last statement. What you said and your tone is what I first addressed; your statements insinuated he wasn't going to be playing newer games and I pointed out that was the goal of his upgrade in the first place. You first use a declaritive statement and then you include some conditional statements? What is with that? That's contradictory.
No, and I never said otherwise. However a higher resolution will be more demanding on the video card, so it will make his video card slower. And that is now the real debate here, and is the point of my second post, but this is after pointing out what was wrong with your very first reply.
So yes, I do think something was wrong with your first reply, as I've already discussed. But to recap the problem is mainly how constricted and contradictory it was.
you are hilarious. I wasn't aggressive at all so please re read everything the op said and you would see that I was simply addressing each part of it.
you are hilarious. re read everything the op said and you would see that I was simply addressing each part of it.
LOL, really? Really? Really? You're calling me hilarious when you are the one with extremely poor communication skills?
Now I've seen it all; I think I'll just give up now.
you should not have even tried in the first place. again I was trying to address every part of his OP. what you did was take one sentence out of my comment while ignoring the rest. there is only one reason that you did that and you what it is so stop before you screw up the entire thread.
A gtx460se,5770,and gts450 recommendation is stupid if a gtx460 for $93 is avalable.
I'm looking to get a reasonable video card for the occasional game, using a 7600GT right now and just play a bit of CSS gungame, nothing heavy. I'd like to try some newer/better games.
Does that sound like someone who cares about 768mb versus 1gb of memory?
hahahahahaha, I'm laughing at anyone who spends the energy typing for this argument.
In fact , I"m outa here, this is ridiculous.
It's like having a nagging wife that needs to be right.
yeah a gts450 kind of ends up in no mans land because of the deals on the gtx460.
lol at you guys going at each other, thanks for bringing some entertainment into my thread. 😀 seriously though I appreciate all the different views.
I apologize if I was unclear -- right now, I mostly play CSS because Mass Effect and Bioshock don't run all that great. For sure I will be trying other/newer games, who knows what I might like. Back in the day, I played a lot of Starcraft. I remember having a system with a Cyrix 166 CPU and being amazed at how much better my friend's Pentium 133 ran Starcraft. lol. I haven't gotten into SC2 yet, but I probably will soon!
The $93, Galaxy 768MB GTX 460 is $149 for me. Since I'm in Canada I'd have to order from Tigerdirect.ca, see here : http://www.tigerdirect.ca/applicatio...096&CatId=3670
The one I've ordered from NCIX is $149 for 1GB, so I'll stick with that.
I remember, probably more than 5 years ago now, I put together a system with a Ti4200. That card lasted the life of the system (5+ years).
The idea with this upgrade is that I won't have to upgrade for quite some time. Unless of course there comes a game I REALLY wanna play, you all know how that goes. 😉
Newegg.ca
Well would ya look at that. heh.
So in the end I'll have paid more for the 1GB, which should still be good if I get a better CPU.
Edit: A few points about the Galaxy card. I've never heard of Galaxy before, and some of the comments I read about it include having a loud fan. I dunno if this might be normal for many 460 cards though. Though I've heard of EVGA, this will be the first time I purchase one of their products.
$93 GTX 460 is tough to beat.
But if I had to pay 150 I'd consider a HD 6850/6870. It's a low wattage, high performance card. Moreover, it's the current generation ATI card whereas the 460 is last generation since they are doing 5xx now. So it'll probably be supported longer.
Only $149? That isn't bad.
1. Strawman argument.
2. You obviously missed the part where the OP referenced NCIX. That means he's in Canada. That means he isn't getting a $93 GTX 460.
3. The OP is asking for advice and I'm giving it to him. At his resolution I would even consider the 460SE > 460-768. If he finds them for the same price, then I'd suggest the 460SE. If the 768MB is significantly cheaper, then it would be a good option.
4. Don't be passive aggressive in your call outs. Do you know how annoying that is? Something a nagging wife would do... Ok that was just a joke and I couldn't help myself. But really, should I now say, "It's stupid to link to American deals on video cards when the OP is in Canada"?
5. I'm laughing too. At you using strawman tactics and red herrings. And at the irony of calling others a nagging wife when you in fact are doing the same thing.
I have a right to point out inconsistencies and clarify the situation. That is why I did it. And look, the OP came in and basically said what I was trying to say in the first place. He wants to play new games but he can't. You declaratively stated he's only playing CSS with that one sentence, and that is why I singled it out. And here's another example of a communication failure...
Right now I'm just disgusted. Simply disgusted.
I would consider a CPU upgrade in the future. I know this thread has been about video cards, but with Sandy Bridge out you should watch for sub $100 Q6600's that should be a drop in replacement but should bring a big shot of extra performance.
If your board can support the newer quads you have even better chance of hitting a good deal.
I wouldn't treat this as a priority, but if you see a good deal on something better you should hit it. I would either get a quad or push the big button and do CPU/Mobo/Ram with DDR3 hitting $30 for 4GB.
I think you did the right thing in buying the 1GB (especially at your high rez!) It would be bad to be regretting that a year from now. I am hoping I don't regret the 1GB 5870 that UPS is bringing me now, but with any luck in 2013 I'll be refreshing the whole thing.
I would tend to agree with your idea. When I put this system together it was really just to get away from the Athlon XP2600+ while spending as little as possible. My system turned out to seem really fast in comparison so that was good. But this left me with a system that can't really be upgraded as much.
While I'd prefer to keep the motherboard, it limits me somewhat if I wanna upgrade. I heard the E5200 is supposed to be a good overclocker. I tried increasing it in the BIOS even by just one increment and it wouldn't post. So I left it alone.
It does support the Quad processors, but up to how recent I'm not sure.
Intel Core 2 Quad Q9505 2.83GHz 1333MHz 6MB $236.99
the same chip with 12MB L2 $277
hmm
HAHAHA - no! You can't make any *wrong* decisions here, but that would be throwing money away. I would be willing to help you buy a Core i5 2400 CPU (new sandy bridge) and mobo for that much from Microcenter if you don't have one locally.
My threshold would be getting a quad for south of $100 if I were in your shoes. Q6600, Q9400, etc.
lol.
GrayTech Computer, Q6600 - $3,981.68 (???)
INTEL Q9400/2.66/1333/6MB UPGRADE $112
ehhh....
so for $240-270 I can get motherboard+iWhateverCPU ?
What about ram? i currently have 4gb ddr2-800 (2x2gb)
a work friend has a p7p55d-e lx (or something like that), might be able to get it for $100-120. wasn't originally gonna go for that... but if I can get a good deal on an i5 maybe it's worthwhile?
don't really wanna spend more than the price of the previously mentioned quads though
