Tidekilla115
How is the r9 380 compared to the gtx 950?
Excellent Cooling Performance One 120mm preinstalled fan in front, one 92mm optional fan in rear, one 120mm optional fan in side panel ensure excellent ventilation and system cooling for all your needs. Plus, the simple yet elegant mesh front panel allows for increased airflow through the case.
The i3 is higher clocked (not by much), has hyperthreading (can process 4 threads instead of 2), and supports AVX instructions (which are HUGE in scientific computing, but rarely used by games).
There are cases where an i3 6100 can be significantly faster than the Pentium, and others where you'll see virtually no difference. It really depends on what you're doing. In something like Battlefield 4 64-player online, the i3 would provide a significantly better experience than the Pentium, but you're giving up a lot of GPU power to hit the same pricepoint, meaning your experience in GPU-limited games will not be as good. I'm normally an advocate of spending more on a CPU and less on a GPU because CPUs don't become obsolete nearly as quickly, but I don't think there's really a wrong choice here.
Will I have any problem with bottle necking with the pentium and the r9 380?
At some point, probably. But no matter what you do with anything, at some point, some part of your system is going to limit another.
If you're talking the difference of an i3 to that Pentium, I'd say the i3 is just a little less likely to be a bottle neck. If you're comparing it to an i5, the i5 is far less likely to become your bottleneck.
If you pay $65 for a CPU, you're getting a $65 CPU. It is a darned good value for what it is... but it is still a $65 CPU.
No I don't I'm going to try to find all the parts I can used.Also im pretty good at fabricating and I have a dell case(dimension e521) but my question is it worth modifying or would it be better to get a case like the fracture which is more breathable and has more options for fans?Do you mind used parts? I have built quite a few solid gaming machines from "recycled" Dell machines with selected replacement parts.
Start with something like this Dell OptiPlex 990 with an i5-2400/500GB/W7 for $200.
http://www.ebay.com/itm/Dell-Optipl...863319?hash=item3abda5ce97:g:sAQAAOSwUuFWw7JQ
Then add these:
2x4GB DDR3-1600 $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148719
Corsair 500W modular PSU $35AR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050
HD 7950 $125
http://www.ebay.com/itm/VisionTek-H...580242?hash=item33b2a66092:g:fCAAAOSwPc9W1ykS
This meets your $400 target, barely. By far the most gaming performance you're going to get at this price point. If you have extra cash you can add an SSD, which definitely helps general snappiness, but doesn't really do much in-game.
One note - this Dell case has an HDD cage built in that blocks long GPU from being installed. You have to drill out the rivets holding it to remove. Long drill bit is your friend. 🙂 Pull everything out of case, drill out rivets, pull out cage, reassemble with old and new parts, enjoy.
I've been watching some videos and it's impressive what the pentium can do.and you can over clock them but everyone who was doing it was doing it on a z170 but they had them all the way to 4.6 ghz. But it didn't seem to change the fps much just a couple frames on average
