Help me think of Older Games
Dec 28, 2001
11,391
If you're into turn-based strategy games, I'd say give Jagged Alliance 2 a try.
Would Half-Life 2 work on that laptop of yours? I'm not sure, you might want to give that a whirl too.
Oh, you can probably look here and most of the games listed there should work fine. I'd definitely recommend checking otu Planescape: Torment if you're into RPGs.
Good luck!
styrafoam
2,684
If you like HOMM you could try the Age of Wonders games, similar in that they are turn based and 2-d. You can pick up all the xcom games from steam for cheap, they fall into the same catagory too.
kalrith
6,628
7
Podracer was a lot of fun with a controller. I would try that or some other old racing games.
