Originally posted by: KPSHAH316
can someone explain how to power shift, and shift without the clutch? I have a friend who is really good since he worked as a valet, and has shifted without using the clutch in three different cars- 02 Nissan SE-R, 92 Accord, and 01 Civic.
You just have to match the revs. IE, if you're going from 3rd to 4th you pull out of 3rd and drop it into 4th when the rpm matches the speed for 4th gear. I've done it before. Its useful if you happen to have a clutch failure while driving (ie a cable snapping)
thats what he said-match the revs. where does the rpm match the speed for 4th gear though? Can you explain what that means really? Also, I understand what power shifting does, but how do you do it?
Also, is this bad for the car at all? I would think if you fvck up, it would be bad for the syncros, but theres no wear on the clutch from this.
I must say, the best experience with stick I ever had was when I drove an evo and it went to 60 in 1st gear-that was fun
