Originally posted by: Shanti
Many high profile, elite schools have a major problem with grade inflation. They do this to keep their average GPA statistics and retention rates high. This helps maintain their status and reputation for academic excellence. As other's have stated, some of these schools never give grades lower than C's, no matter how poorly someone does. So in many cases, it is actually easier to maintain a high GPA at some of the "elite" schools.Originally posted by: WinkOsmosis
No, they are not necessarily harder just because they are ivy league schools. Harder to get into, yes. Harder coursework, not always.
It is definitely possible to get into good grad schools with a degree from any university. They will place far more emphasis on GPA, GRE or other grad exams, and professor recommendations than on what school you graduated from.
A state university is NOT a junior college.
hergehen,
since you said you are planning on graduate work, I'd suggest you stay at the cheaper school, work your ass off to get the best grades you possibly can, do everything you can to make connections with professors who can give you recommendation letters, and study as much as possible for your GRE's or whatever exams you will need to take. Then go to the best grad school you get accepted by.
Once you are done with your graduate degree, nobody will care where you did your undergraduate work. If you think your grades will drop by going to CWR, then I think this would hurt your chances at grad school admission far more than having your undergrad degree be from a lower prestige school.
The only people who say that are the ones who go to crappy schools. How do you suppose a school that has on the average MUCH SMARTER students can be at the same level of difficulty as a school that has the dummies?
As for grad school... Pretend you are Harvard. Would you rather admit a grad school candidate who went to Cleveland State or one who went to Duke?
All else being equal, you are right, they would pick the person who went to Duke. But if the Duke student has a 3.1 GPA while the Cleveland State student has a 4.0, the choice is clear.
Originally posted by: hergehen
Actually, the thing is, the most probable grad school that I will go to IS Case Western, so by going there as undergrad, it may be give me more chances to get into their grad school ?
If their grad school gives preference to their own undergrads, then yes, that might be a good reason to go there for undergrad. You need to find out if that is indeed the case.
Personally, I think if the Duke student has a 3.1 and the CSU student had a 4.0 it would be close. The Duke name recognition offsets the GPA.
