Originally posted by: dileepsv
Looks mainly.. and stamina.. i play lotsa basketball n badminton so..need sum stamina fo that..i gues basicaly i want abs..muscles..trapz..coz those are wat the outer stufz are..
Originally posted by: KoolDrew
If you want a 4-day a week routine, something like Lyle McDonalds bulking routine may be a good idea...
Mon: Lower
Squat: 3-4X6-8/3' (3-4 sets of 6-8 with a 3' rest)
SLDL or leg curl: 3-4X6-8/3'
Leg press: 2-3X10-12/2'
Another leg curl: 2-3X10-12/2'
Calf raise: 3-4X6-8/3'
Seated calf: 2-3X10-12/2'
Abs
Tue: Upper
Flat bench: 3-4X6-8/3'
Row: 3-4X6-8/3'
Incline bench: 2-3X10-12/2'
Chins: 2-3X10-12/2'
Triceps: 1-2X12-15/1.5'
Biceps: 1-2X12-15/1.5'
Thu: Lower
DL: 3-4X6-8/3'
Leg press: 3-4X6-8/3'
Leg curls: 2-3X10-12/2'
Split squats: 2-3X10-12/2'
Abs
Fri: Upper
Incline bench: 3-4X6-8/3'
Chins: 3-4X6-8/3'
Flat bench: 2-3X10-12/2'
Row: 2-3X10-12/2'
That much volume may be too much for you though. If it does become a problem switch to 2-3X6-8 and 1-2X10-12.
Id like to basically work out the entire body n tone the muscles... ive got monday - thursday inclusive with an hour n 20 minutes per day to work out...help me build a schedule for each day...
Abs - Monday
Weights - Tuesday
Legs/Calf Muslces - Wednesday
Chest...- Thursday
Thats my base schedule...please add any part that needs to be worked out...
Thanks so much!!![]()
Originally posted by: TalonOP
That's too much unless the OP already has already been lifting for a while. Need stats / pics before deciding on appropriate schedule.
I'd suggest something like Mark Rippetoes Starting Strength program then.
Workout A:
Squat 3x5
Bench 3x5
Deadlift 1x5
Workout B:
Squat 3x5
Military Press 3x5
BB Rows 3x5
Alternate each one and go to the gym 3x a week. The original program has power cleans in place of BB Rows though. If you feel you can do power cleans or have somebody show you, do them. If not, BB Rows will work fine.
Workout A:
Squat 3x5
Bench 3x5
Deadlift 1x5
Workout B:
Squat 3x5
Military Press 3x5
BB Rows 3x5
Starting Strength is a pretty good program and simple beyond belief. I personally would do crazy just doing those 'cause I'd probably get bored with the same lifts over and over.![]()
Workout A:
Squat 3x5
Bench 3x5
Deadlift 1x5
Workout B:
Squat 3x5
Military Press 3x5
BB Rows 3x5
Yes, but as a beginner the emphasis should be placed on learning those lifts properly, since those lifts should be the emphasis on ANY routine, regardless of how complicated it is. And there's no better way to get better at something than to do it frequently.
Also, when just starting he should be seeing strength gains pretty much workout-to-workout, making it a lot less boring.
