YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
- Aug 6, 2001
- 31,205
- 45
- 91
Originally posted by: sygyzy
YOyoYOhowsDAjello - Thanks for the link. It seems the overwhelming consensus is that the 1014 is the better choice over the AVR325. But what about the 425? or 625? I think the price difference between the 1015 and 1014 is small enough that if I went the Pioneer route, I'd go for the 1015. Another big debate is between the Onkyo 602 and the 1014/1015 it seems as indicated by http://www.fatwallet.com/forums/message...58105&highlight_key=y&keyword1=pioneer">this thread</a>. What do you guys think about Onkyo? I am really looking at things in the 400-700 range. It's easier to make comparisons when you are comparing the same range.
So I think that includes Onkyo 602, HK 425, 625, Denon 2805, and Pioneer 1014/1015, right?
To clarify: you originally were leaning towards the Axioms but since it has the most disfavorable reviews, you were pretty much set on going with the Ascends. Then the Rockets came along? So if it weren't for the rockets, you were going to go with the Ascends, despite the Axioms being your initial choice?
Thanks for the info regarding the Paradigms. The Studio 40's are a step up from the 20's (right?) and if the Ascends outperform them, then that is all I need to eliminate them from the running.
Thanks so much for the links. The extra bit of time you spend in your posts really helps me figure this all out.
Still having a tough time deciding between all of this. I have a handful of choices for speakers (well mostly Axiom or Ascends), the subs (HSU vs SVS) and receivers.
Unless you need 3 component inputs, I think saving the money and getting the 1014 would be a good pick, but that's just me
Maybe you should call your local Best Buys and see if they have some floor models left :Q
Note that my thread was about the 325 and not the 335 in case you didn't notice.
The 1014/1015 are very powerful units (really put out 100watts+ per channel)
The Pioneers will have auto equalization setup like the HKs would too.
Your Onkyo link wasn't working for me.
I think all the receivers you mentioned would be very solid options.
A lot of people who have Ascend speakers have mentioned how well they pair with HK receivers for great sound. I didn't come out with other suggestions initially because I think an HK would be a great choice for an Ascend combo.
I really haven't heard many brands of receivers so I wouldn't want to appear like I could give you personal advice on this. Everything I've read over at AVSforum and hometheaterforum though would indicate that any of those would make great choices.
For the clarification...
For about the past 8 months I thought that if I ever was looking to get some new speakers, I was going to get an Ascend Acoustics set. (Since I kept reading about how great they were for the money and couldn't find any dirt on them to make me think twice).
So, after months of waiting for Fluance to come out with a new center channel (which they still haven't), I started thinking about getting a new center channel from a company that I would someday want to build a whole system around.
My initial thought was to get an Ascend 340 and keep using the Fluance speakers for the rest of the system.
So, a couple weeks passed and I talked myself into just going ahead and paying for a whole new set of 5.0 speakers. Again, my initial thought was Ascend, but I thought I'd look around at the other brands I had read so much about on forums.
Axiom was my first thought and I looked into what kind of system would be comparable in price to the Ascend system I was thinking about.
Over the next few days I added Onix Rockets, Swan, and B&W to my list of brands to look into.
So, I spent several hours looking at professional and user reviews of the options from different manufactureres.
I did Ascend first since I already had a pretty good idea of what to expect. Seemed like an excellent option.
I moved on to Axiom and got a bit worried when I saw several people not liking the tweeters on them.
I really wanted to order speakers online because it seemed you got a lot more bang for your buck that way, but as you mentioned, shipping speakers back seems like quite a hassle.
The negative comments on the Axioms (although as I've mentioned, overwhelmingly they were positive comments) made me want to hear them for myself before considering ordering them.
Then I moved on to Onix Rockets and Raiden256 made a thread for me over at AV123 to audition them.
I have that thread linked to in my speaker thread.
Althought it was well above my original budget, the rocket ultra 550 deal seemed like an awesome choice. AV123 has deals from time to time where you basically pay for a 3.0 system and get the surrounds for free. Basically it was like paying for a bigfoot center and a pair of 550s and getting a second pair of 550s for free.
So, seemed like a good deal.
I read some more about Ascend vs Rockets and the 550s vs the 340s seemed like a close call.
All signs pointed to the RSC200 center channel from the Rockets as being a nicer center channel than the 340 though.
Since my initial quest was for a better center channel, having an awesome $600 center channel appealed to me.
I e-mailed AV123 and Ascend a bunch with different questions I had. They were both very very helpful. I don't remember the number of messages I sent off the top of my head, but it was somewhere in the neighborhood of 30.
I set up and audition of the Rockets with a guy in the Milwaukee area (MikeD) and listened to them.
They sounded great to me and nicer than the speakers I had auditioned earlier at a local audio store (some Monitor Audio and Klipsch).
I pretty much fell in love with the Rocket real wood veneer too. Since Ascend was my initial thought, you can probably tell that I wasn't buying speakers to look pretty, but once I saw the Rockets I changed my mind.
I spent a couple days thinking about a 5.0 Ascend 340 system vs the Onix Rockets Ultra HT trying to decide if it was worth the extra money and I ended up going with the Rockets.
Yeah, the Studio 40s are a step up from the 20s.
40s retail for $1200/pair and 20s retail for $800/pair.
Price List
Going up past the Studio 40s is mainly better bass response if I remember correctly. With better bass than the 340s, I saw the Rocket 550s being compared to the Studio60s more often than not (Even the studio 100s at times).
From what I've read, Rockets, Paradigm Studio, and Ascends are all pretty similar sounding in the great scheme of things.
The big difference from Paradigm is the price
A good deal of the cost (perhapse 50%) is the markup to keep the retail outlet making a profit.
I think picking out a receiver was the toughest thing of the choices I've made. Good luck!
I think it's going to be hard to go wrong with any of these options you're considering :thumbsup:
