::::HELP:::: LiveUpdate is on Crack!!! Problem Solved :o}
LoneWolf1
1,159
LiveUpdate is trying to use a non-existant dial-up connection.:disgust: How do I configure it (LiveUpdate) to use my broadband connection?
W98se
IE6
<edit/>Deleting the dial-up connection from Internet Options Control Panel solved the issue.:D
Rent
7,127
Make sure you don't have a fake modem installed...
did you just move from dialup to broadband?
Maleficus
7,682
lots of other forums you coulda posted this on.
Tech Support
Software
wutever
LoneWolf1
1,159
<< Make sure you don't have a fake modem installed...
I just did a format and clean install. I have a modem installed as a back up connection.
Rent
7,127
Ok, in IE6, hit tools, then internet options, then the connections tab. Make sure it says "never dial a connection"
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Whats with the cross posting? I just answered this in Operating System's, it certainly doesn't belong in Off Topic. (Let me guess 'Off Topic gets the most readership so I posted it here' ;))
Bill
