Perhaps condsider a used 7950-7970/280-280X. If you are willing to buy used, you may find one of these great cards in your price range.
100% agreed.
Used 7950 is going to be miles better than a 750 ti and you can find it for $100.
People on here often fail to remember that most Gamers don't need max settings or 60 FPS.... Medium settings on modern games is basically PS4 level.
It's a small percentage that do and most are found on PC forums![]()
Sure, there are better cards available at a similar price to the 750ti, but none remotely close to it in power usage.I'm trying to run my system with less power and noise.
All of the discussion about better cards in the price range is ignoring this important point from the OP:
OP, your point about noise is well-taken. Just like I have to concede to AMD on VRAM, I have to concede to NV on noise. Their Maxwell cards are just a lot more quiet/efficient than AMD cards, who in turn are not loud per se but there is a difference.
