OpalFrost98GT
Originally posted by: oldsmoboat
There could be frost that you are not seeing. If the defrost heater is not working, the coils are covered in ice and are not working correctly. The defrost heater is most likely behind a removable panel inside the rear of the freezer. If the timer is bad it could be stuck in defrost mode and the heater in the freezer is staying on. It could also be stuck in the normal mode, not allowing the the heater to come on and causing ice to form on the coils. The defrost heater itself may also be bad.
Ornery is also correct about the port. It is usually located low in the refrigerator section.
This is exactly what happened to mine. A guy came out and used a torch to melt the accumulated ice off of the coils. Been fine since. The coils are inside in the lower rear portion of the freezer section...SideXSide.
