You're joking right? Everything is always screwed in. There's a bracket that comes with the SSD to make it fit properly. Or you could just do away with having a case altogether, just let everything dangle freely and breathe happy! lolHow secure do SSD's need to be in your rig. Like you just lay it somewhere on the bottom or you gotta make sure its screwed on and all that jazz!
Let us know how the rma turns out for you. My first sf ssd, adata s599 croaked before it was 3 months old and it took adata over 3 weeks to complete the rma process. Now I'm using an ocz agility 2 120gb as my boot drive with it being cloned to my adata replacement drive as backup. Intel and samsung ssd's are looking more appealing all the time.
Sounds like you might have some other issues. Using atto my wd black drive has maximum transfer rates in the 150 range, about half of what my agility 2 does.
Even w/ AHCI? I've been mostly been using F3s and F4s, these days, and the above is almost unfathomable. Even copying small-file-filled drivers and source code, I rarely get under 10MB/s. 90MB/s for large files is about right. Though, the system seeming almost unusable compared to an SSD would still be the case. W/o AHCI, I would go crazy using mechanical drives, today.Dropped it at the post office today, so we'll see how this goes. I wonder if it's even possible to have an SSD run nice and stable on this computer at all.
I was copying some files from one WD Black to another WD Black, 500MB of drivers (so I don't have to redownload them after I do my next reinstall), could not sustain a file transfer rate above 1.6MB/s! :| Next I copied some video files which did go up to 90MB/s but dropped to just under 50MB/s before finishing. Not to mention the system was near unusable during the file copy. I can't wait to be on SSD again!
I don't think any of them do compression. The actual type of file should not have any effect, but size will, as will how often it has been written to, for large files (fragmentation isn't the problem it used to be, but highly-fragmented large files won't copy as fast as large files of few fragments).I had no problem getting numbers above 100MB/s in benchmark (ATTO) for both my WD Black drives. Copying other files, I was in fact able to transfer at 100MB/s but it seems the type of file being copied will dramatically affect the transfer rate (compression?).
Sigh... I really hate seeing people having all these problems with SSDs. They really just need to work, now, for everybody in every computer.
They work perfectly fine as long as you avoid SandForce and OCZ.
I must be the luckiest guy around this joint then.. cause all 7 of my drives work flawlessly on just this system alone(and 6 are in R0 so go figure that one out).
Then there's the other 4 running on friends/family's that haven't missed a beat either. Have to know the limitations of all hardware involved.. and know how to set them up, I guess. 😎
My other 8 OCZ drives spread about the other systems around here are also without issue. Maybe I should be playing the lottery more often, eh? 😀
Just run off your WDC and RMA your SSD. I don't think firmware can bring a dead drive to life. Hope the RMA goes fast and you get your drive back. gl
