That depends on what you will do with the system. If you are overclocking it then an aftermarket HSF is a good idea.
Gaming, but no overclocking.
I still like aftermarket coolers even when not overclocking. The are quieter and keep the CPU cooler. I personally can't stand the sound profile of Intel coolers, especially when they ramp up the RPMs like when gaming or doing CPU intensive tasks.
There are basic ones in the $20 range with higher-end ones near $100.
I like quiet - which one would you recommend for this, I saw the one above to check.
Edit: I realized I already got the Hyper 212 Evo - that should be good enough?
not sure if it's totally successful. poweron temp is 60c, and before an mmo would drive it to 121c then poweroff, now it went to 95c.
These temps are high, but are they high enough to be a problem?
A possibility is to replace the cpu sink with a higher quality unit (eg, uses copper fins).
Those temps aren't good at all,
This. I have an inexpensive 1 gallon compressor that I use to blow my system clean every few months or so. Comes in handy for cleaning filters of various kinds (vacuum cleaner, clothes dryers, etc.). No substitute (including those canned products) for 40 lbs. of compressed air.use compressed air.
its' faster and easier just hold the fans from spinning.
