And I didn't even give you a reach around. Just bent you over the thimble. Damn, I'm good.
If that's what you want to tell yourself buttercup, I was impressed on how much you improved your gag reflexes.
Effing rooffie....If that's what you want to tell yourself buttercup, I was impressed on how much you improved your gag reflexes.
Makes sense. The reason wind cools you off, is that it evaporates the sweat from your skin. If the humidity is near 100%, the evaporation will be low even if there is a wind. I have read that if the temperature is above body temperature, a wind will make it feel warmer, although I am not sure that is correct. I think the heat index is a bit incomplete though. I dont think it takes into account whether it is sunny or cloudy, and that can make a big difference in how your body reacts.https://graphical.weather.gov/definitions/defineApparentT.html
Subjectively, wind doesn't seem to make much difference when it's warm, and humidity's high.
I ride through several neighborhoods and I can tell you that the shaded areas are like an oasis comparatively.I dont think it takes into account whether it is sunny or cloudy, and that can make a big difference in how your body reacts.
Effing rooffie....
