Originally posted by: Jessica69
Well, AT's testing showed a system draw running 2 x 4870 in CrossFire under full load, with a QX9770 cpu on an Intel DX48BT2 motherboard, to be at 421 watts....and remember, that's a full system load, not just the video cards.
Basing on what you have found, if one was to run 2 HD4870X2s in CF configuration, with an e8400, a 700WATT could run them?
Wow, so the highly-vaunted HX620 isn't supported?Originally posted by: Jessica69
If you're asking if a 700W power supply will run a pair of 4870's in Crossfire, I don't know about that since the lowest wattage power supply certified by ATi/AMD for just that scenario is 850W, at least so far.
I wonder if the Antec Earthwatts 650W will support two 4850s in crossfire.
Originally posted by: unr3al
The HD4870 in xfire requires at least 600W (official requirement) so I don't think the X2 will require any more than that. It would more likely be less power-hungry than an xfire between two HD4870s.
AMD really got it right this time. First great product since the merge.
