It's not just weeds, its also "some" grass. Lawn has been pretty pathetic for years, its time to do something about it.
Stop posting in every thread, especially on issues which you have zero clue on. If you actually read the OP, he's trying to kill his lawn and not just kill weeds.
OP - what are temps at night? If the grass has already gone dormant, the grass blades may not absorb the herbicide.
If I want to make scrambled eggs for two. But the direction says one egg for one person. Wouldn't it be reasonable to use two eggs for two people?The directions say 6 ounces per gallon.
What is so difficult about that?
I wanna. My post count must rise.
Maybe i didnt read the whole post.
I actually do have experience. I work on my lawn instead of my dad. We rarely use herbicides. If he is trying to kill his lawn, just increase concentration. So maybe 6oz for 3/4 of a gallon
You don't need to "saturate the lawn" with Roundup--wasteful. Only the leaves are affected.
In my experience (as recently as last month), it takes 1-2 weeks for the plants to go completely brown or yellow after I spray Round-Up on them. My guess is that your lawn is becoming dormant, but if that were the case, then why is it still green?
What exactly are you spraying it on?
Probably the low temp. But the new/improved roundup is not as good as the old stuff. Used to be 1oz/gal....bastards. Had great success with the local farm supply concentrate and it was way cheaper. 1 gallon of concentrate ~$45.00....3 oz/gallon mixture.
Glyphosate has gone generic. There is no need to buy 18% concentrate glyphosate as Roundup when you can buy 41% generic glyphosate. Either way, the chemical takes a week to ten days (or longer at cooler temps) to work. Mix up only as much as you can use at one time. Glyphosate breaks down quickly in soil, and it breaks down just as quickly in tap water, so whatever you have left over will be worthless if left in the sprayer for use later.
You can buy different strengths of the concentrate...
And there's the answer I was waiting for...Round-up isn't an "instant weed-killer." It can take up to 2 weeks or more to do its job.
One thing I've found that DOES make it more efficient is to add a bit of liquid dishwashing soap to the mix. Makes it stick to the plants better...and (according to one of my college professors) "makes the water wetter," so it's absorbed by the plant better.
I'm not a kemest, so I dunno about that last part, but in a one-gallon sprayer, I add 2-4 oz. of liquid dish soap...and the Round-up works fabulously for me. Just don't expect miracles...and instant weed/grass death. It takes time to work.
If you wanted to do better in school, you'd think you would stop posting so often, especially from school. And being annoying here, more than probably reflects your persona in real life and might explain some of your social issues.
Shut your mouth, I have seen the Roundup commercials.![]()
Do you have children?
If so, play a new game with them called pulling weeds.
We have. We pulled bermuda grass out for many hours about a month ago. Didn't make a difference as the rhizomes were still there and resprouted.
Edit: A bottle of Roundup that makes 10 gallons markets for somewhere around 22 bucks. A bottle of generic that makes (iirc) 22 gallons is typically around 12 bucks. I don't really feel like paying for Monsanto's advertising, so I just get the generic.
Glyphosate only enters the plants through the leaves. If you pull it up before you spray, then the plants that resprout after that never got treated. That is probably your problem.
Couldn't find the generic at the two hardware stores I went to.
This is what I purchased:
http://www.acehardware.com/product/index.jsp?productId=1391833
Visible results in 12 hours
The leaves were not there when I sprayed, they came down in the past couple days.
You need to go back and re-read everything that has been posted.
We pulled the bermuda grass over a month ago. It has since resprouted. I treated the lawn 11 days ago.
Follow the timeline...
I'm trying to kill everything on top of the ground right now.
It can still be resprouting after a month. Regardless, your main problem is probably that you expected results in three days to begin with. Glyphosate only shows those kinds of results when it is hot out, if even then. It is slow acting.
You do realize that you can till it now, right? You can apply glyphosate and till the next day. Once it is in the plant, it will work whether you till or not. You don't have to wait for it to die first.
SOIL TEST before you try to grow anything else.It's not just weeds, its also "some" grass. Lawn has been pretty pathetic for years, its time to do something about it.
