Have I been shifting wrong my whole life?
Chryso
4,039
13
Originally posted by: vital
it is illegal to drive in neutral because if you get in an accident and lose control or pass out, your car won't stop from rolling down a hill.
If you are driving an automatic and the car stays in drive your car also won't stop from rolling down a hill. It will also keep moving on flat ground.
Lonyo
21,938
Originally posted by: AccruedExpenditure
Originally posted by: GuitarDaddy
1. Engage clutch
2. Step on the brake
3. Once stopped shift into first
4. When light changes, gas and go
This is terrible for your clutch... you can't stay in first without the clutch engaged when you're at a full stop...
I leave the cluth depressed and put it in 1st if it's a short stop, but if it's a longer stop, stick it in neutral and take out the cluth (like red lights that have only just turned).
jagec
24,442
Maybe the gov't acknowledges that slushbox drivers are drooling idiots, and doesn't expect as high quality driving out of them :p
imported_Phil
9,837
No, you haven't been shifting incorrectly. However, coming to a stop from 35mph in neutral = bad idea. What happens if your brakes fail, hypothetically? There's not a lot to slow you down apart from other cars :p
Plus, if you need to get the hell out of the way of something quickly, shifting back into gear and biting the clutch might be the difference between getting out of the way and becoming a flat mess against the grill of a truck.
AndrewR
Originally posted by: jagec
Originally posted by: AndrewR
Originally posted by: ITJunkie
That's the way I always did it. Down-shifted to ease wear on the brakes and idle in neutral to spare the clutch.
I used to think that way, too, but what's cheaper to replace: brake pads or a clutch (regarding downshifting)? I don't down-shift anymore. :)
You oughta get 100k+ miles out of your clutch either way, so it's a non-issue for me. Besides, if you revmatch when you downshift, your clutch wear is so near zero it makes little difference. And you SHOULD revmatch when you downshift.
My clutch has over 120k right now so I'll stick with using the brakes in lieu of downshiftng, except on snow/ice (which won't be an issue when I return to the States in late May).
MikeMike
45,885
66
as an FYI, its illegal to ever be out of gear on the roadway unless you are broken down...
AgaBoogaBoo
26,108
Right, but even that little amount doubles in use if you downshift once everytime, triple if if you go through more than one lower gear. That, and it's not needed really. During daily driving I hope your break pads aren't having an issue with the stopping without downshifting...
Eli
Super Moderator | Elite Member
8
I only shfit into neutral at a stop if the light is excessivly long and my clutch leg is getting tired.
Stiff clutch springs FTW!
B00ne
2,168
Originally posted by: Phoenix86
Originally posted by: cecco
I was always taught to downshift. That way the car would always be in gear in case i had to manuver.
However, in some countries in Europe I think they require you to be engaged in gear at a stop. Not 100% sure on that.
Never heard of that
jmagg
2,233
468
Thats called freewheeling and no its not good. Always be in gear.
Eli
8
Guess that's not true.. There's a long, realitivly steep grade that I have to go down on the way home from work.. I always throw it into neutral and coast down it, saves a bit of gas.. lol
CVSiN
9,289
QFT..
car should be in gear incase you have to emergency manuver the wear and tear is negligable
arcenite
10,660
7
QFT..
and plus you get the race track effect
DivideBYZero
24,117
Is your car fuel injected? if it is, you are wasting gas if you coast down a long hill! Ask me how!
jlee
48,518
223
PSA:
Break != Brake
If you don't downshift, you lose some control over your vehicle. I'd rather replace a clutch every 150,000 miles than always coast to a stop. When you overclock your computer, you sacrifice component life..but will it ever be enough to notice? Probably not.
BD2003
I usually just keep it in whatever gear I was in, and use the brakes to slow to a stop. It uses zero gas whether youre at 1000rpm or 5000rpm. I could downshift, but then Id have to revmatch, which is more trouble than its worth for the one millionth of a chance that something crazy happens and Id actually be fast enough to do something about it.
PeeluckyDuckee
4,464
Whether to downshift or shift to neutral, no single answer can be right or wrong. Its sometime circumstancial (sp?) and a personal preference. I do however prefer to err on the side of caution.
If it makes that much of an $$ issue to you then you probably shouldn't be driving a vehicle in the first place, if that is your primary concern.
AdamSnow
5,736
I downshift until I'm in 1st gear and stopped... if I'm on a flat road I do not hold the brake down, but I always leave my clutch engaged and waiting in 1st gear... when it goes green I disengage the clutch and am on my way.
Kalvin00
12,705
I will put it in neutral and coast to a stop too....my truck won't accelerate fast enough to 'get out of the way' of something anyways..
cecco
265
It's all about the ability to exercise control over your vehicle. Downshifting gives me the option of doing just that in case of an emergency manuver. i.e. car stopped in the middle of the road, incoming fast car from behind, or a brake failure. It is why i like standard better than automatic. More control over the performance of my vehicle. :)
jlee
48,518
223
You mean you leave your clutch disengaged? Engaged in gear would cause you to stall. :p
skyking
22,792
5,961
If any of you drove a semi, you'd quickly learn to shift that thing into nuetral as you coasted to a stop and leave it there till it was time to go. Foot off clutch.
Holding your foot on the clutch with the tranny in gear causes wear on the throwout bearing. No biggie in most cars, but it requires a transmission removal to fix, just like the clutch.
On the semi, the force required to hold that clutch in is proportionate to the size of the rig. That's why a trucker judges his speed so carefully in stop and go traffic, and tries not to stop. It is not only the wear and tear on the clutch and rig, your leg will ache like crazy:D
I downshift about two gears coming off top speed, and let the brakes do the rest. I leave it in the lowest gear I downshifted to, say 3rd in a car. When it becomes apparent that I will be stopping, I put it in nuetral and let off the clutch.
With the truck, I might jake downshift 3 gears, max.
AMCRambler
7,715
31
In my car(manual) I usually leave it in whatever gear I'm in and just brake as I come up to the light. When my rpm's drop below 1500 I can usually just pull the shifter out of whatever gear it was in. Don't need to push the clutch. Is this what you're talking about?
skyking
22,792
5,961
getting it in nuetral with the foot on the floor, not on the clutch, yes:)
Kroze
4,052
why not revmatch when upshift too?
