- Oct 10, 1999
- 30,990
- 12,539
- 136
I will make this simpler for you to understand:Originally posted by: Wuzup101
Originally posted by: Iron Woode
I am not sure which point Spidey is unhappy with, but Super-Chargers and Turbos increase apparent compression ratio and that is why they generate more power. O2 concentration stays the same.Originally posted by: Wuzup101
Care to point out where I'm wrong?
I shouldn't have to in all honesty. It's glaringly apparent.
No go ahead though, I'd like to hear it. While I didn't preach about how forced induciton systems work, the differences between a belt driven S/C and a turbo feeding off the exhaust (to produce the same BASIC) effect, etc... I'd like to have more than a childish "you're wrong." Hey, I'm here to learn too. All of the systems above in some manner increase power by increasing the amonut of O2 that can be fed into the combustion chamber. I wasn't trying to write a thesis on the subject, just say that that's the same basic idea. With more O2 you can burn more fuel which leads to more power.
Yes and no. Yes, they do increase the apparent compression ratio (and yes this does also inrease power). However, the O2 concentration doesn't stay the same. The compression (of the air) itself increases the O2 concentration (the amout per unit volume). Hehe, I wasn't trying to say that a CAI and a turbo or S/C were the same thing by any means in my origional post (I thought I pointed that out), just that similar thinking was involved.
all the S/C does is compress the air. It does not change the ratio of O2:N. It does not remove nitrogen from the incoming air. It just compresses it so it takes up less space and is more densely packed. It also heats up the incoming air charge, so a cooler is a good idea when running lots of boost.
air is always 21% O2 and 78% N.
