TraumaRN
Sheesh. I make my own pie:
1) Put pizza stone in oven. Preheat to 500F.
2) I use a Boboli THIN CUT WHEAT crust as my base.
3) Smash about 3-4 garlic cloves and add this to about a 1/3 cup of extra virgin olive oil. In addition, add (to taste) salt and pepper, oregano, crushed red pepper, paprika, and fresh basil paste. Stir the resulting mixture.
4) Pour mixture evenly onto crust.
5) Slice 1-2 vine-ripe tomatoes into 1/4 inch (or smaller) slices. Arrange pizza crust with tomato slices in a circular pattern.
6) Place about 15-30 black olive halves in a random pattern on tomato slices.
7) Repeat previous with julienne-cut sun-dried tomato pieces.
8) OPTIONAL: Slice thin pieces of your favorite cooked sausage and/or salami and add this to the bed of tomato slices as well. I personally like to use organic chicken sausage.
9) Grate your favorite assortment of cheeses, such as parmesan and/or mozzarella.
10) Place into oven onto pizza stone. REDUCE heat to 350F.
11) Allow to cook for 20-30 minutes or until cheese is nice and brown and bubbly.
Excluding shopping time, I am sure you can do the above in the time it takes you to order and wait for Pizza Hut, not to mention the above would be much healthier.
Why turn the heat down?? Especially if using a stone.
My pizza is either ordered from a local place about a half mile from my house, which has hands down some of the best pizza I've ever had. But then again they make dough fresh daily, cut the veggies daily and even slice their pepperoni while they make your pie.
1.)Otherwise I make my own dough. Let it rise at least once before I start to shape it.
2.)I use a gigantic slab unglazed adobo clay that weighs about 20 pounds to bake on.
2.)Oven at 550F convection bake and it stays there. Because of the giant slab of clay this usually takes upwards of 45 minutes.
3.)Shape dough into desired shape, rectangle is easiest to make. As thin as I can but slightly thicker on the edges.
4.)Brush olive oil and sprinkle with fresh chopped rosemary/oregano/thyme/basil from herb garden
5.)Grate whatever cheese I have on hand. Usually smoked provolone and either aged Asaigo or Parmesan. Sprinkle onto pie
6.)Chop fresh tomatoes, onions and mushrooms add to top.
7.) Change oven to convection roast(essentially broil but with the convection fan running too)
8.)Put into oven for no more than 7 minutes, unless you like nuclear burned pizza. 6 minutes for a chewy crust.
Devour.
