oh sorry 6-8 core, was thinking that many sockets for some reason.
I blame lack of coffee and recovering from a serious network looping issue![]()
they have a dedicated hypervisor you can run now
Yes I am aware. It is a Windows 2008R2 standard core install with a hyper-V role. You get the same thing from doing a Standard Core install from the CD. My point from above was I see lots of people throw files / dhcp / dns on the base host not realizing they consumed a license when they did so.
I havent installed it but I thought it was merely a hypervisor now, but I havent installed CORE just standard so I dont know the difference between those
work and renovating my house are keeping me from really playing at home![]()
It truly is just Windows 2008R2 Standard Core with the ability to add roles and features removed.
The 4 Virtual machines per Enterprise license applies to VMWare also. Same with the Datacenter unlimited rights.
The key with hyper-V is to be really careful because just adding "DHCP" to the host-os makes that license go from "free" to "1" meaning you can only virtualize 3 instances. Basically the host must do hyper-V only and nothing else to "not count."
No, VMWARE does not come with free MS Server 2008 R2 licenses. If you install Windows Server 2008 R2 Enterprise (Core or Full), you get the rights to install 4 Windows 2008 R2 server guest VMs on that server (in other words, you speedn ~$2000 for an Enterprise license, and get to install 4 $600 licensed copies of Server 2008 R2 under it)
Yes.... Hyper-V doesn't come with free Windows licenses either.
It is very simple (for Microsoft at least):
ESXi - Windows 2008R2 Enterprise -> 4 virtual installs
Hyper-v - Windows 2008R2 Enterprise (assuming only hyper-v role. Any other role or feature uses a license -> 4 (or 3) virtual installs.
It gets a bit more hairy because your supposed to license boxes where the instance *could* reside. IE 2 servers need 2 licenses even if you only use 2 virtual instances etc. The only exception they make is for HA operations while licensed hardware has failed.
