Hanging a 50 in plasma on drywall?
BoomerD
66,278
14,699
A REAL man would simply hang the TV from a Kabar driven into the sheetrock far enough that it penetrated the exterior wall.
Everyone knows this.
Kanalua
4,860
Originally posted by: Kelemvor
Just mount a couple boards across the wall to the studs and then mount the TV rack thing to those boards.
this...even some 3/4" plywood or something...
sdifox
100,249
17,895
Stop hanging tv on walls. It looks good in magazines but it performs poorly since it is usually mounted too high.
olds
50,122
778
I just mounted my 72" in the sheetrock directly over the bed on the ceiling. But it perfectly in line with my eyes. It should perform OK shouldn't it?
moshquerade
61,504
12
56
Go 150" or go home
sdifox
100,249
17,895
Sigh, I shouldn't have to tell you this, but the TV goes on the wall and the mirror goes on the ceiling, ok?
moshquerade
61,504
12
56
no.... believe me... it's good for olds to do it that way. :Q
BeauJangles
13,941
Nonsense. TV + mini pc + webcam = win.
ja1484
2,438
Originally posted by: h8red
I just mounted a 55" TV on the wall using toggle bolts. I used this mounting bracket. I was lucky that I could drill into the stud and use lag bolts for the center anchor but I still used four toggle bolts around the corners. This TV will not come down unless the house comes down.
Yes...because it's in the stud.
