Had LASIK with IntraLase and VISX CustomVue hours ago
tnitsuj
5,446
How long was it between your initial consultation and the surgery? Was it difficult to schedule?
Auric
9,591
Originally posted by: steppinthrax
I never got it down but from what I understand it's just a machine right???? I mean what is the doctor doing. There is a computer doing most of the mapping controlling the laser and everything. I imagine if you had the machine at home and all related training manuals you could do it yourself?
Yeah, the whole "doctor" thing is just a scam. As is the so-called "specialized equipment". I mean heck, I already have a laser pointer, hobby knife and a mirror. I figger I'll just take a shot of whiskey, bite down hard on pencil and have at 'er.
Capt Caveman
34,543
651
Originally posted by: FearoftheNight
someone told me not to pursue lasik due to the fact that it accelerates or causes severe vision deterioration 10-20 years down the line. is that true? i was seriously considering this procedure until i heard that
I don't believe the procedure has been around long enough to definitely be able to provide long-term affects.
BLHealthy4life
1,297
Originally posted by: DukeAbercrombie
had that done too, the pred forte drops are disgusting tasting once they drain
Yeah...
weird being able to taste the drops going into my eyes.
BLHealthy4life
1,297
1 week. I had a consult on a Thursday, the following Thursday I had LASIK. I believe I was the doctor's 10th surgery that day....
It wasn't difficult to schedule.
BLHealthy4life
1,297
The vision in my right eye is getting pretty good. My left eye is definitely lagging and it's annoying as hell.
Night vision isn't the best right now, lights still have halos....
Another 7-10 days everything should be good..
marvdmartian
5,444
27
I thought about it, but then saw how much they wanted, to do my eyes locally, and said WHOA!! :Q
Add to that the fact that I'm 45, and thus going through the 2nd change of my eyes in my life (either that, or my arms are getting shorter!! :laugh: ). I've worn glasses since I was 8 years old, so really don't think about NOT wearing them now, ya know? Tried contacts back in the 80's, but gave those up when I got something in my eye, that I swore I'd rinsed out, and succeeded in scratching up my eye with it! Now, working with fuel like I do, contacts would be a big mistake, especially if I took a shot of fuel in the face......laminated eyeball!! :shocked:
Anyways, I figured that if the lasik only corrects the near-sightedness, but I still end up wearing readers for close vision, then that'd be a huge waste of money I'd rather spend on something else.......and hearing you say you spent $4600, that comes out to enough pairs of glasses to last me probably the rest of my life!
Glad ya like it, tho. :)
BLHealthy4life
1,297
my eyes are almost fully healed.
In the last three days I have seen tremendous improvement each day.
I'm thinking that by Sunday, everything will be perfect.
A5
4,902
I'm going to get it once I get a real job and hopefully have insurance that helps pay for it (not counting on it, though). At this point my glasses cost about $250/yr after insurance costs (wtg VSP), so even if I can get 20 years out of it, it makes anything under $5000 worth it.
ShinmenTakezo
19
Since it seemed like several people in this thread mentioned issues with dry eyes, I figure I'd throw some options out there. I'm a 3rd year medical student, and I just spent a month on an ophthalmology rotation. I also live in Nevada which is the dry eye capital of the world so I've seen pretty severe cases and have probably seen most of the available treatment options.
If you've had LASIK, PRK, or LASEK in the past year, I would stick with the preservative free tears that come in the single use disposable vials. If they aren't working for you I'd consult with the doctor who performed your surgery before adding any other type of over the counter tears.
There are a lot of over the counter tears that you can use which most patients find solve their problems. Optive is the newest and seems to work well from the patients I've talked to. Systane is also a popular one. Everybody is slightly different and it's good to try different brands to see what works for you. Most people find that using them 3-4 times a day is enough, some may need more applications and some may need less. They can be used as many times as you like, but if you find yourself using them more than 5 times a day it can become tedious, and that's when most patients try to find an alternative. If you want a more longer lasting drop, there's Refresh Liquigel that is more thick and viscous. It lasts longer but it also can blur your vision for a few minutes after you use it. It's probably best to use it before you go to bed at night or right when you wake up. I would stay away from Visine or Murine as they are only useful for cosmetic purposes to decrease redness. They work by constricting the vessels in your eye and if used too often can cause a rebound effect by making your eyes even worse than you started.
If OTC tears aren't working or you find them too inconvenient, another solution is punctal plugs. Your tears are produced by the lacrimal gland and drain through the superior and inferior canaliculus down to the nasolacrimal duct into your nose. A silicone plug can be inserted into the cnnaliculi to prevent drainage and keep your tears in your eye. It's a painless procedure and literally takes less than a minute to peform. The plugs can always be removed if you find them irritating, and they make temporary plugs made out of collagen that only last a few days before they dissolve. Some patients like to try these as a test run to see how well it works or to see if it causes them discomfort.
There is only one prescription treatment that actually both increases tear production and improves the quality or tears called Restasis. They've started running TV advertisements that you may have seen recently. Restasis is a topical Cyclosporine drop that needs to be administered twice a day. Most people use it when the wake up and before they go to bed. It's safe to use an OTC topical drop like Optive or Systane during the day in addition to Restasis. I believe about 85% of people find it improves their dry eye condition. The downsides are that it takes a long time for it to work, sometimes it stings for 10-15 seconds, and it's also somewhat expensive. It comes in single use disposable droppers but if you save them, they can usually last for 2 days or 4 applications. Some people are apprehensive about using it because Cyclosporine was originally used as an immunosuppressant agent for transplant patients and if you google Cyclosporine, you find that it can have some severe systemic side effects. With Restasis you don't have to worry about those because you're using it topically and you also get extremely small amounts of it in comparison to the quantity you'd have to take to experience side effects.
Unless you have extremely severe dry eye syndrome, you should be able to get relief with any one or combination of solutions I've mentioned above. If you're using tears, plugs, and Restasis without any success, the last option I know of is an OTC oral pill called BioTears. You have to order it directly from the website of the manufacturer, Biosyntrx. Your tears have a lipid, aqueous, and mucus component and BioTears basically is a mix of fatty acids and other miscellaneous ingredients that in theory should help with tear quality. It's kind of a long shot and any improvement is minimal at best, but it doesn't contain anything that could cause harm and I've met some patients that claimed it helped. I Caps is multivitamin that works along the same principle, just with a different formulation.
That basically covers most of what's out there. As I mentioned before, I'm just a student and these were what I saw being used at the practice where I worked. Your eye doctor may have a different strategy for treatment. I would highly recommend talking with your ophthalmologist about if your dry eyes if OTC tears aren't cutting it. You would need to see him/her anyways if you wanted plugs or a prescription for Restasis. Hope that helps and if there are further questions for anything, feel free to ask.
Vich
2,849
Good response ShinmenTakezo.
I will echo the point to talk to your opthamologist before starting anything new. When I was wearing contact lenses I started to experience severe dry eye. felt like sandpaper in my eyes. I started taking OTC drops and nothing helped. It turned out I had blufferitis (sp?). Which is an inflammation around the eye lid.
Point of the story is, you might think its one thing when its actually something else. Dont take a risk with your eyes!
dug777
24,778
4
I've thought about it, and i have the money, but decided I'm very happy with my glasses :eek:
Rookie
1,178
I had PRK done about 3 months ago now... probably at least 20/20...
Do your homework, understand the risks and if it's for you, GO FOR IT!
I'm glad I did!
TechBoyJK
16,699
60
Originally posted by: BLHealthy4life
bump for update
I had it done back in 03, where the flap had to be cut surgically.
I don't regret it, but my vision seems to have slightly degraded since then.
I still don't need glasses and am happy with my current eye sight considering what I dealt with prior.
I get some mild halos at night, which are cool and sparkly, hehehehe
I'm thinking about going back for a "touch up" to see if any of the enhancements in technology could make it any better.
pstylesss
2,914
This really depresses me. I've had glasses since I was 8. I went in for a consultation and they said because of the shape of my eye I didn't qualify. bastards.
sdifox
100,988
18,120
Yeah...
tear ducts are hooked up to your nose/throat.
And I am too chicken to have some frigging machine driving a laser around my eyeballs.
RgrPark
1,086
It was that easy for the doctor to re-lift the corneal flap the second time because it never heals right after LASIK. According to studies, it only has 25% of the tensile strength. When I heard about the woman who lost her corneal flap years after the surgery when her dog accidentally licked her eyes, i knew LASIK was not for me.
MotF Bane
60,801
10
Does anybody know if you can be fully sedated during this? When I tried to get contacts, as soon as the doctor touched my eye, I passed out. He said it was something called "vesa vega", or at least that's what it sounded like he said.
KK
15,903
4
I'd like to see this woman, somehow I don't believe this woman exists though.
