gtx570 or 6970?
Wont' be playing till like 4am friday morning the build will take place on the 1st late in the evening if not early am friday.
Think for the occasion i will be playing it most of the day on my 37 inch 1080p t.v.:biggrin:
If you log into battlelog in the next day or two add me my screen name is skipsneeky on there and i will accept when i test out the new rig😉
Friend request sent!
Don't touch anything with FX in front of it.
I really recommend a 6950 2gb over a 6970, there's absolutely NO reason to ever pay $100 extra for a 6970 when 6950s are almost certain to over-clock to 6970 speeds or beyond.
Blast frys and their combo deals damn them to hell lol .
They have a fx 4100 combo deal going for $170
http://www.frys-electronics-ads.com...MD-FX-4100-Processor-Asus-M5A88-M-Motherboard
Will bring my savings to $130 and going with a 6950 over a 6970 can leave enough room for a $220 1920x1080 monitor so i can get out of the stone age with my 1600x1200 now.
This is their only combo but what cha guys think?
You've said money was not the limiting factor, so don't go for an FX 4100. Note that no one criticized your choice of the i5-2400 (I think I might have planted that one in your head, actually), because it's solid for non-overclockers. The FX 4100 is not. In some games it will lose to an A8-3850: http://www.legitreviews.com/article/1766/13/. Wow, just wow.
As for the GPU, I'm actually going to go with the GTX570 here. But not because of MSAA, which the GTX570 most definitely cannot handle at 1080p. Rather, it's because the GTX570 is slightly cheaper and offers more consistent performance than the HD6970, as shown in the apples-to-apples [H] comparison linked earlier: http://www.hardocp.com/article/2011/11/22/battlefield_3_multiplayer_performance_iq_review/4.
If you find an HD6970 for the same price, I'd go for it just because it's slightly faster in most games.
Since that post and now events have happened as to where my budget has been chewed down a tad bit.
But yeah i decided to ditch the fx4100 a long time ago after doing some digging but my build will have a i5 2400 and a gtx560 ti or possibly a 6950 if i can make that card work in my budget.
6970. you want the 2gb to last you for 2 more years.
MSAA is a waste in bf3. The dev worked hard on the fxaa/morphological aa and it shows.
I own a 6970...though I think I will be swapping it out for a 570 I just bought for my brother. All the benches I've seen for BF3 show the 570 beating out the 6970. Add the further overclocking potential of the 570 and you basically have a 580. I really don't think VRAM is a issue until you get into multi-monitor gaming.
In this case, stretch to the 6950 if you can. It's a faster card.
Source: http://www.tomshardware.com/reviews/geforce-gtx-560-ti-448-core-benchmark,3082-4.html
I'm assuming these benches are with MSAA applied. The OP will have to decide for himself whether these are the ones to look at. Not even the GTX580 is playable at those settings.
My new and final budget allows three situations....
i5 2400+lousy h61 chipset that will come without my required usb 3.0 sata 6 and 6 port audio for my 5.1 speaker set up with pure luck of fitting in a 6950 in.
i5 2400+halfass h67 and no matter which mobo i pick i will get the option of a gtx560ti only as my best option.
1090t+970 offering sata 6 and usb 3.0 with full 6 port audio for my 5.1 with options ranging me from a 6950 to a gtx560 ti 448 core to a gtx570.
Frys may have a pny gtx570 for $310 if so thats my first choice with a gtx560 ti 448 core as my second if they carry it at the $310 or lower price tag with the 6950 in a close third.
frys usually is good about new selection i picked up a evga gtx280 hours before it was even published on evga.com so i'm sure if the gtx570 isn't a option the 560ti 448 core is.
Not gonna kid myself with anything less then a 6950 even if it means a 1090t build.
Seems like the 1090t+970 is way cheaper than the i5-2400/H67. Is it some special bundle deal? If so, I can't really argue with that. But if you provide the actual cost of each CPU/MB combo, it would help. Obviously you have some other requirements (USB3/audio) that are pretty important and favor the 1090t/gtx570 solution.
The cost of a capable i5 2400/h67 setup providing all i need with audio usb and sata will cost me around $60 more then it would for the 1090t.
The $60 difference where i am shopping gets me into gtx570 territory while i get stuck with a gtx560ti if i went with the i5 2400 and a chipset that offers no tweaking of any kind.
The gtx560 ti original does not appeal to me at all with some games not pulling 60fps at 1920x1080 and games like BF3 kinda putting any 1gb card to the pasture if you want some 1080p or ultra and the trend will continue.
Nickle and dime build this time around😉
i5 2400 $200+
MSI H67MA -e45 b3 $115 plus $15 for a heatsink
1090t $170+ asus m5a97 $100
The i5 2400 i wouldn't think of building without a heatink the stock is garbage and the msi brand as a whole i hate and avoid.
The 970 choice mobo offers all the msi offers and more for less with better quality overall and the 1090t has a decent heatsink for minor overclocking.
Given the price difference, I'd get the 1090t. It's a fine CPU, and you're getting the platform features you want for a nice price. I think it should drive BF3 just fine. See my post in a separate thread to show why:
http://forums.anandtech.com/showpost.php?p=32571604&postcount=438.
Whereas the 1090t isn't usually better than the X4 CPUs, the extra cores really make a difference in BF3. When pushed to the limit, it will provide the same minimums as a 2500k, which is the key issue.
Based on the other thread you have going, I know you've decided on the 1090t anyway, just giving you more backing for that decision.
Go with SB and a Z68 motherboard, get a cheap GPU or use an old one for a little while longer until 28nm arrive.
Z68 allows you further upgrade-ability in the future, whereas the AM3 platform is a dead end now.
Silverforce - in general, that's good advice, but the OP already has BF3 and has been trying to play it on his dual-core without success. Given a set budget, SB/Z68 without a high-end VGA isn't the best solution for playing BF3 right now.
This build will have to be it sadly,cutting back on spending of pc parts.
Not gonna go batshit crazy for BF3 the only thing i will be getting is a ssd in the later half of next year when prices drop maybe to replace a 3 1/2 year old seagate 1.5tb and a new monitor.
2 years ago heck i would have boughten a 980x and dual gtx295s but idk the hobby for me is sorta dying with fewer game titles grabbing my interest and making me want insanely speced towers...🙁
Final specs:
1100t@3.8ghz
asus m5a99x
4gb ram bought 8 had a bad stick causing a no boot
evga gtx570
hyper 212 plus heatsink
Frys had some sort of intel cpu dry spell the only cpu in the entire store was a dusty i7 950 for $299..apparently intel according to a few workers has had manufacturing and shipping issues...
The 1100t was the last on the shelf being a returned one in fact and i guess the intel dry spell had people going and scooping all 1090ts..
Overall i love the build 🙂
Not a single 6970 of any model on the shelf heck there was a 560ti 2 win and 3 6990s in stock yet not a single 6970...
One bad stick of memory ended a 6 year streak of zero out of the box dead components and my first build to give issues on initial first boot up due to this stick...
Final specs:
1100t@3.8ghz
asus m5a99x
evga gtx570
That's a great build. Congrats. So how's BF3 treating you now? 😉
What brand of memory did you buy? If you manually set your frequency/timings while just the 1 stick is in, you might be able to use the second stick. For instance knock it down to 1333 cas 9, or even 1066.
The kit was patriot g2 low profile dual channel 8gb.
Well the memok red led on my motherboard would flash red with both sticks.
Sometimes it would boot with both hitting the memok button sometimes reset a few times then it would randomly get going not booting mode again.
Putting them in different slots as a pair i might get lucky then finally after dicking around driving myself looney i put one stick at a time in...one stick boots...second does not.
When i got a boot it would run on auto but dram voltage was at 1.5v at 1333mhz..thinking the motherboard was being picky about the voltage i raise it as high as 1.68 to see if this gets the thing going.
It trucks on for about 3 reboots till finally it decides to not boot up again with the memok red led on the mobo flashing.
Hit the memok and everytime it goes out of b*tchmode and boots i get f1 overclocking failed...bios is 0705 about 3 months old so gonna update to the latest 813 and see what happens.
Don't run on auto. Set everything manually with one stick and see if it works. Set it at 1333, 9-9-9-24, 1.65v, shut down, and put the second stick in. If that doesn't work, then yes, the memory is clearly faulty.
I did end up testing both sticks by themselves in all available slots the one stick simply refused to boot in any slot....
Unless one stick simply does not care for the auto while the other one does?
I will try setting it manually then ill slap it in...ill report back in about 20 mins or sooner with my results.
I have both cards. They are close in performance and each one shines in certain games. I don't think you will go wrong with either. Best thing to do is get the one that runs the games you want to play the best.
