toyota
- Apr 15, 2001
- 12,957
- 1
- 0
that's a deneb quad core so he is fine with any gpu upgrade.What you have is actually a good match for your CPU too. Probably don't need anything until a complete overhaul.
Given the two 1GB models are generally +/- 3% performance delta, the only reason to get one over the other at this point are price and/or thermal concerns.
you made us do all this bickering and in the end you are playing at lowly 1440x900? lol. yeah a 9800gt should still be decent enough for that.
I said his 9800gt would still be "decent enough" at 1440x900 and it will for the most part. also at 1440x900 512mb is not an issue at all. other than GTA 4 it would offer no benefit especially on a lower midrange card.Well, my 4850 was starting to feel too slow for 1680x1050, so I can imagine a 9800GT just barely cutting it for 1440x900. People are not playing Oblivion and the original Bioshock any more. The latest DX11/10 titles can really stress the last-gen DX10 cards. Also, only 512MB of video RAM is a problem in many new games, where you are forced to turn the texture detail down.
As for the PSU, it should be fine for either card unless you do some extreme overclocking or already run your CPU at 1.6V or something crazy like that.
My 450W PSU handles a Phenom II at 3.4 GHz/1.35V and a GTX460 factory OC'd to 700MHz just fine. I've run Prime95 with the "maximum heat" stress test with Furmark running at the same time. The PSU fan speeds up, but nothing blows up and there are absolutely no crashes or voltage fluctuations. You will however get higher efficiency, lower temps and lower power usage with a GTX460 and/or a better PSU.
There is nothing wrong with that 585 power supply. I've used dozens of them in builds and even in higher end systems. While the power supply is NOT 80 plus, it does have about a 75% efficiency rating which is still respectible especially for the price.
Thats all just my opinion and experience of course.
Jason
the psu that the op has is NOT enough to reliably power his system with a gtx465. the psu doesn't even list what its truly capable of on the 12v lines combined but rest assured its well less than what it would be if you just added them together. just using common sense would tell you there is a reason that its a 585 watt psu for 26 bucks. formulav8's post is sort of meaningless because efficiency doesn't have squat to do with the psu not be strong enough.I've noticed that enthusiasts love to WAY overkill on PSU's to the point of ridiculousness.
