- Apr 15, 2001
- 12,957
- 1
- 0
the point was that just because it was a revised card doesn't magically mean it will get the same performance increase as the others did. the other cards(580,570,560) all added more sp and tmu along with faster clocks. the gtx550 still has the same number of sp as the gts450 and only upped the clocks and memory bit width with corresponding rops. so again based on its specs it is performing like it should.You said it is performing like it should. The person you quoted said it is not following the trend that was set earlier by the 560Ti and that name (numbers) of the 550Ti are deceiving.
560Ti is comparable to the performance of the GTX 470 (within 5%, while that's not really the case with the 550Ti and GTX 460 since the performance difference is around 15% according to the benchmarks.
