Yes, but what fan speed? I just have a reference card, and that's with fan under 50%
Ok? And I wanted to cut down on the noise and have.
edit: also, you didn't say if 54 was 10 minute of furmark@ 1920x1200 with no AA temps or not. Nothing else gets this over 50C now.
Nothing is comparable with furmark temps. Nothing at all
Sorry.
3 hrs of Heaven 3.0 is..
Anywho... the results of that 180$ thing..
Makes me thankful i did not buy one.. Instead going the Antec 620 route may not look as pretty but it is 110$ cheaper and gets better results.
No, no it really isn't. Once your cooling system reaches an equilibrium, no amount of running is going to raise your temps. You can run it for 100 hours and it will make no difference.
You must not have ever owned a Non Ref Tri fan Gpu...
Thing is like a Leaf blower in your case..
I was also benching 60mhz higher then you aswell..
Big Question what tim did you use?
I used Cool Laboratory on the gpu.. Tried it on my cpu temps were 5-6c Higher then IC diamond... So i scraped the crap off put on IC diamond back on my cpu...
So when i install the Antec 620 mod on my non ref ima use the IC Diamond.
We can compare temps when you actually run a similar test. Lol.
Surprised the top card heated up at all, considering almost all the heat should be shooting out the radiator and not touching the inside of your case.
My temps are lil bit higher then most are reporting on OCN i think it is due to the tim i used.
but meh im not downloading furmark..
i Have 3d mark 11 and Heaven 3.0 i will also down clock my card to your clocks.
Why not? I'm sure i'm not the only one interested to see the difference. Even if your temps are a couple degrees warmer, I'd say it would be the better solution. If I can spend 10x less for something that will net me 75C over something that's getting 71C, i'll let my GPU warm up to 75C without thinking twice about it.
Well personally, i'll let it warm up to 80C since I'd never spend close to $200 for a cooler of any type.
2is, it only hits 64C in furmark. 71 is my non-special cooled one.
