Got me thinking..
2Xtreme21
7,044
Originally posted by: thirdlegstump
I heard from a pilot friend of mine that if you throw a lit cigar out the window, the missile will go after it instead.
Yeah just "open the window" of your supersonic jet while you're spinning around like crazy trying to avoid getting stuck up the ass by a SAM. Good advice.
ChooChooChooseMe
2,746
Originally posted by: slag
I always thought they jettisoned the tanks for more manueverability.. shrug
What always works in the movies is to launch missiles at a rock wall and then fly towards it. Veer right or up or left at the last second and the missiles crash into the wall.
Works for torpedoes too. :thumbsup:
KillerCharlie
3,691
68
If it's heat-seeking (infrared), about all you can do is flare and try a sudden maneuver. Infrared missiles are extremely deadly, extremely fast, and extremely maneuverable. It's unlikely that any sudden move will do much. However, they have a very short range (unlike that BS in Behind Enemy Lines). Longer range radar-based missiles, though, give you a bit more latitude. The best thing you can do is do a 180 and fly away (if it's launched from long range) or fly normal to the missile so it takes a long time to catch up with you.
Atheus
7,313
They are jettisoned for maneuverability. No way would blowing up fuel tanks create the same IR signature as correctly burning the fuel in a turbine.
Are they that complex? So a heat seeking missile has a computer system which stores profiles of aircraft and compares against incoming images? That must take a pretty serious amount of processing power...
pontifex
43,804
46
bahahaha
either your friend is an idiot or you are for believing him.
even if it did create enough heat to throw off the missile, how do you open the canopy of a jet thats going several hundred mph?
KillerCharlie
3,691
68
bahahaha
Sorry, but you're the stupid one for believing he was serious.
slpaulson
4,414
14
I don't honestly know, but I wouldn't think it would take that much processing power. It's pretty much just a 2d signal detection problem. I'm sure those missiles cost as much as they do for a reason.
novasatori
3,851
The unique head-seeker also extends the lethality of the missile by aiming it to the target's most vulnerable areas. Most heat seeking missiles tend to home on the hottest spot of the aircraft which is normally the rear exhaust system. In modern combat history, some aircrafts that were hit by a missile in that area, managed to survive the flight until the landing. The Python 5, which acquires a sharp image of the target can home on the most critical areas of the aircraft, such as the cockpit or the central area, and significantly improve the chances for a shot down.
the Python 5 claims this ability, of course its really hard to know what the missiles can and can't do.
There is also a sample picture of what an IR seeker on a missile sees, but I'm sure its a bit higher resolution straight out of the missile.
91TTZ
14,374
They're fairly complex. They lock onto temperatures which are common in jet exhaust, and can discriminate against other heat sources. If they built them to just go after the hottest heat source they see, you'd have missiles going after the sun 90% of the time.
Oct 20, 2005
10,978
44
bahahaha
beat me to it
waggy
68,143
10
I heard that they open the canopy and light a fart with the lighter first. it really confuses teh hell out of the missle.
Oct 25, 2006
11,036
11
Its perfectly Possible to dodge a missile. You just need to dodge it so that the proximity detonator wont activate and fill you aircraft with shrapnel.
While missiles out maneuver and out speed Jets, Jets have humans inside them, who are capable of making complex maneuvers.
Just get out of the missiles detection cone, and the missile will lose the lock.
Gibsons
12,530
35
Modern IR missiles are scary good. Text
There's another video of the 9X out there that's better than this one, but I can't find it.
Gibsons
12,530
35
Originally posted by: tenshodo13
Do you mean the one where the missile made 10 consecutive 180 degree turns?
don't remember everything about it, but it showed a little text (and maybe even a diagram) before each shot explaining what it was supposed to demonstrate. There was an off-boresight shot and an amazing shot that ended a Lufbery, a few others.
pontifex
43,804
46
bahahaha
right, because he made every attempt to let us know he was joking :roll:
of all the tings i've read on this forum, it would not suprise me if he thought it was true.
Sukhoi
15,350
Yeah, that's what I meant. They discriminate by wavelength. Though like some people are linking the newest seem to actually be able to track a picture of the plane and aim for certain parts.
skyking
22,892
6,059
the ability to vector in on center mass is not all that complex. Usually there is a component of forward motion on the missile that is along the same path as the plane itself, a tail chase. it would not be too difficult for the software to move forward of the tailpipe a certain percentage.
Demon-Xanth
20,551
Basically, the pilot has to jerk the stick and try to dodge. Once you dodge once, the missle's pretty much lost you. But the trick is to do that dodge, then make sure another one doesn't get shot at you.
gerwen
312
Why would dropping fuel tanks defeat the missile's tracking systems?
Some missiles are radar guided, rather than heat seeking. Fuel tanks present a large radar signature.
No idea if it would be effective though, that's what chaff is for.
MattCo
2,198
bahahaha
Comon, his comment even set off my faulty sarcasm meter. :)
TXHokie
2,558
176
Divert all power to aft shield, flip on your cloaking device, worst case jump to hyperspace. Easy!
