OILFIELDTRASH
- May 13, 2009
- 12,333
- 612
- 126
Are the front fenders and doors on that car fiberglass?
I didn't either, else I would have stripped the grill, front fog lights (custom ones), and air lid+CAI.
if you dont, the guys at that yard will, as soon as you leave from getting "your stuff" out of it
Looking like the average for cars with the same miles and such around is about $14k...not sure exactly how the insurance thing works. I have another grand into the stereo (was able to salvage a lot of it), then it had modifications. Anybody know of exactly how it works, or how it has worked in past situations? Police report said estimated $6k of damage...I think there is a bit more than that.
I actually talked to the guys at the yard, older black guy who owned it, they were cool...we looked at the engine and it could easily be salvaged, he said it didn't look like there was any big frame damage if any, but it was probably gone.
Be prepared for a battle. The insurance company will likely want to give you a check for far less than what the car is "valued" at on the open market. They also will not add in anything for modifications. Just get examples of similar vehicles and be prepared to show them what an actual replacement will cost (minus mods, they won't budge there) and let them know you won't accept less.
That car is gone. No doubt about it. I bet the body work alone is more than the total kbb value. Looks like every piece of the body needs to be replaced. I don't know what the cop was thinking with the 6k estimate?
Front fenders are, hood is as well if it's an SS. I believe the doors are metal.
For owning one of these cars, you sure don't have your facts straight on them![]()
Front fenders and the bumper are a urethane plastic. Hood is fiberglass if SS, the smooth hood is steel. Doors are fiberglass (with metal crash bars for reinforcement). Rear quarters are steel. Rear bumper is urethane plastic like the front.
Hmm, my doors held a magnet so I assumed they were metal. Plastic/fiberglass, meh. What's the difference! Close enough. :awe:
crash car, post in ATG ASAP.
:thumbsup:
glad you're ok man
Chrysler on GM violence is unacceptable. Find a 300C and smash it with a baseball bat.
+1 T
Good to know your ok.
Do I hear a new build thread being made...?
Probably caught a door bar.High strength light weight ultra high tech space age super advanced synthetic composite turbo injected polymer resins.
Hey it works for BMW, Ferrari, etc. :awe:
Might have been sticking to the metal reinforcement bar or a window rail.
I'm a little CDO (OCD, but alphabetized like it should be! :awehence why I had to be so picky over the material
