Good PSU brands?
Googer
12,576
7
Originally posted by: Zaputh
I am going to get a new PSU for my Dell XPS 410. What are the BEST brands for PSUs? I want one that'll cost me between $50 and $75 and has a minimum of 450W. Thanks for the help!
Beware that Dell uses proprietary PSU's and the only decent manufacturer that can offer a quality exact replacement fits the DELL schematics is PC Power and Cooling.
http://www.pcpower.com/products/power_supplies/dell/
http://www.pcpower.com/product...lies/selector/dell.htm
If your computer is not listed, give them a call and they will tell you which is the correct one to buy.
John
Moderator Emeritus<br>Elite Member
Originally posted by: bigstrickler
Is rosewill a good PSU brand?
Some are, most aren't. How much power do you need?
bigstrickler
185
I'm not sure...I have a rosewill 500 watt powersupply, lasted me almost 2 years now, no problems...i'm gonna upgrade my computer this summer to a quad core, same ati 1900xt, dunno what mobo yet, 2gb ram....you think i need more than 500 watts?
jonmcc33
Banned
Feb 24, 2002
1,504
Thanks! Haven't I been saying this? Has anyone seen the back of the case? I don't think that it will fit correctly let alone be secure...
John
As stated in my previous post a standard size ATX psu fits the XPS 410. Here's a pic :camera:
Bend the tabs if needed :camera:
s44
9,427
16
Yeah, Dell used to use proprietary connectors and everything, but they've reformed since.
tweeve2002
474
ok this is related. My Pc Power and Cooling 850W Power supply just bit the dust and I am having to replace it. My system is fairly old but I am running 8 hard drives so it needs a lot of power. I ran the power supply calculator at eXtreme and it says I need around a 685W power supply. So Im looking for a good power supply that wont break the bank around a 750W or larger so I can put in more hard drives.
I saw a COOLER MASTER Real Power Pro RS-850-EMBA ATX12V / EPS12V 850W at newegg. Are cooler master PS's any good? its cheap and below $130 after the rebate.
Googer
12,576
7
Dude, that PSU comes with a 5-7 year warranty. Call PC Power and Cooling; they should send you a replacement. Possibly the 1KW model.
EDIT: Many of those PSU calculators are totaly out of wack. Back when I had my P3 with 4 hard drives, several of those said I needed a 730 watt psu but my 430 worked fine.
Each HDD needs about 10-12watts on start up then about 8-10watts to keep running. Average about 10watts per drive and thats only 80watts.
Video 85watts (approximate, your results may vary)
CPU 80watts
Motherboard 25watts
DIMMS 2watts each (FBDIMM is much higher)
FANS 1-5watts
DVD drive 12-18watts.
Estimated Total 222watts. 1 video card, 1 CPU, 2 dimms, 2 5w fans, Motherboard, DVD drive. Power consumption may surge above 222watts during the initial POST screen but quickly settles down once the drives have reached speed.
craftech
779
4
For years I have been using Fortron Source power supplies. I have yet to have a problem with any of them. I can't say that about Antec or some of the others I have purchased yet the very first Fortron Source AT power supply still works to this day. If you open one up you will see why. Quality parts and weight - a factor that can often be used alone to judge a power supply (usually).
John
Googer
12,576
7
Keep in mind that a bad motherboard can short circuit the power supply, sending it to an early grave. Get in touch with PC Power and Cooling for a free replacement.
JEDIYoda
33,986
3,321
Dood call PC Power & Cooling and they will replace it for free!
All there PSU`s have a 5 or a 7 year warranty!
I wouldn`t even be looking at a Cooler Master PSU when I could get a new one from PC Power & Cooling.
Hell they will send you a new one brfore you even ship the other PSU! Then they will pay for you to return the PSU!!
Peace!!
JEDIYoda
33,986
3,321
John
Fortron is a very descent PSU!!
But then again it`s not a PC Power & Cooling PSU!!
Peace!!
aigomorla
21,137
3,675
dont know if anyone posted it.
But heres a breakdown of TIERS.
http://www.xtremesystems.org/f...howthread.php?t=108088
I personally only get PSU's from Tier 1, and 2.
The ETASIS 850W(Tier1) is sold at newegg for 159.99 Personally thats my favorate atm.
let the "omg thats overkill on a PSU" flamewar begin. :\
Googer
12,576
7
John
Peace!!
I can attest to that. My 1KW-SR is makes larger PSUs look puney.
