Ok, checked it out again. Late last night, I wasn't into putting much time in this. I installed HL and Nolf to see if they worked, not much more than that.
I sum it like this (I know I'm repeating myself).
I wanted a card that can play the new games such as BF1942 with I/Q turned up, high level of AA and AF. My Ti4600 could not do that. My choices to replace it were 9700/9800 and 5800. The dustbuster factor of the 5800 made it a non contender. That leaves only the 9700/9800. Basically, a choice of one card. That is what I went with. Can you suggest a better card that I can buy right now?
Are ATis drivers up to nV standards? Not quite.
Is nV 2D quality up to ATi's? No.
Does nV have a card that competes with ATi in AA/AF performance. Not for me they don't.
There are always compromises.
I do have Cat 3.2 installed if that is what you mean. And yes, as I said in my previous post, I have a black screen when I exit the game or actually, when I go back to the menu. The game does run though. If I were still playing HL, this would be a problem. I'm not, so for me, its no big deal.Odd, it is a known and admitted bug(by ATi) that the game hard locks systems whenever you try to go from the game to the menu running OGL. Only thing yet to manage to hard lock my new build, ATi's drivers. Surprised you don't have them installed, next months announcement got me wanting to play through them all again![]()
Ok, now I see it. Its a mouse lag issue, not a raw framerate problem. Again, I installed it quick to check it out. Also again, dont play it anymore so no biggie there. I dont have NOLF2 to try.Try turning around quicklyBFG has the same issue it seems. It doesn't matter what settings you use, from 640x480x16 to 16x12x32x6x16. NOLF2 does not have the issue(although KPC which also runs on the older Lithtech engine does).
