Zenmervolt
Elite member
Originally posted by: Eli
Propane in a gas engine, or diesel?Originally posted by: Zenmervolt
Diesel and an 1800RPM genhead is the only way to go if you care about longevity.Originally posted by: Wheezer
Originally posted by: DahRock222
I'm looking to get off the grid and need some help disigning a good power source. Wind,Solar and Hydro + batterys are in the works but in need to know how many batterys and if i need backup generator
You will need a backup generator almost certainly.
Hint: DO NOT, and I will repeat.. DO NOT get a generator with a regular 4 stroke gasoline engine that spins at 3600RPM to produce the rated output.
If you don't know what I'm talking about, you have a lot of research to do. 😉
any suggestions?
Regular 4 cycle engines will only give a few thousand hours of service before needing to be overhauled.
What about Propane?
ZV
You could build a reliable generator out of a gas engine, but it's all about the RPMs.
A high quality gas engine(read: taper main bearings on both ends, cast iron cylinder sleeve, separate valve guides, automotive quality air filter, pressurized lubrication) can last quite a long time, a lot longer than ~2,000 hours.
Cheaper gas engines have plain bearings, aluminum bores, aluminum valve guides, etc. They also produce their max output at their redline, which is usually 3600RPM. You can see why the engines won't last long under these conditions.
1800RPM genheads are generally designed with a diesel in mind, and therefor use higher quality bearings and are just generally more robust. Beware of Chinese genheads though.
It's hard to build a 1800RPM generator out of a 3600RPM engine. Obviously the engine is producing very little power at 1800RPM..
I've gotta go to a birthday party, I will post more later.
For some reason I was thinking that an LP generator would be using something other than a reciprocating engine.
ZV
