MarcVenice
Moderator Emeritus <br>
The basic idea is to put together three different systems. These three builds will most likely end up in a stickied thread, so new system builders can use these systems as a guide or reference. I'm going to keep them updated myself the best I can and as time allows. A real budget one, 500-600$, a mid to high-end gaming machine for 1000-1200$, and a real high-end machine for 2000$. I would like some input on the exact figures. Do we add in monitors ? OS's ? How much for the keyboard, mice ? I think that for the budget machine we should go with integrated graphics but I want more input on this. If people want to game on a budget we can always put in a sidenote that adding a videocard and a slightly better CPU will do quite well in a lot of games. More input needed on this !!!
The next step will be to piece together these systems. I will also be taking suggestions on that. Some input here is needed as well though. Most of the AT visitors are from the US, so we will be using parts available in the US, and we will be using US pricing. Do we take into account rebates ? Besides this, the middle to high-end gaming machine could also be a Photoshop/video editing machine, all you really need then is a quadcore and perhaps some extra ram. How do we take this into account?
So if you could be so kind, just post answering the next questions, copy/paste will do:
Budgets:
Budget A: $$$, Budget B: $$$, Budget C: $$$
Monitor: Yes/No
OS: Yes/No
Rebates: Yes/No
How much for a Keyboard/Mice ?
Then you can throw in your own 2 cents. I've been doing some thinking but I think we should just get started and we'll see were we end up. These new systems are ALL about the best bang for buck. We're not here to support Intel/AMD/ATi/Nvidia or whatever brand gets you going. We want to build systems that give the most power to the end-user for the least money, within budget of course. Some rebates btw are really persistent, but I think that if we pick a part with a rebate on it, we should also mention a part without a rebate, that still fits the budget.
Post away !
And P.S. I'll be keeping my eyes on this thread. I'd rather have you post in here then PM-ing me directly.
Budgets:
Monitor: Yes/No
OS: Yes/No
Rebates: Yes/No
Post away !
