I think the point they were trying to make is that noise measurements on quite a few tech sites are taken very close to the cooler, which just isn't realistic at all. The only thing these measurements are really good for is comparing relative noise between cards. Sites like SPCR measure from a distance of 1m, which is a realistic distance a user would be separated from the noise producing components in their computer.
That said, there's no doubt the GTX480 is one of the noisier GPUs out there, and is still very loud even in a closed case @ 1m.
Throughout the first minute and 20 seconds I thought it wasn't THAT bad but after that it sounded like a fucking jet took off.Why not listen to the sound and video files recored by Hard|ocp
http://www.hardocp.com/article/2010/03/26/nvidia_fermi_gtx_470_480_sli_review/7
It is pretty easy to tell the 480 is loud.
looks like your attempt at debunking has been soundly debunked, maybe the thread needs a title change?So, we have four reputable sources telling us the card's noise and heat is excessive, and we also have [ H ]’s videos which they claim are accurate as to what they actually hear when sitting in the lab.
Sorry Cookie, but you’re clutching at straws if you go off what Guru3D is saying. The GTX480 is an absolute furnace. We know this from multiple objective and subjective measurements. It’s hotter and louder than a 5970, which is two GPUs slapped onto a single board using the same manufacturing process.
you know the trolls are grasping in the dark when they try to even think of comparing the credibility of AT over g3D. baffling.
They're just doing damage control for their team. At worst, they're doing their job as PR affiliates but anyway.
Enjoy: http://www.youtube.com/watch?v=xfQOU3T0O3Q
The card is a disaster through and through.
Just so we're clear (I don't want my article being taken too far out of context here), our 4890 is not unreasonably loud in that "In terms of pure dB, it's above some magic level of acceptable noise", it's unreasonably loud compared to other 4800 series cards. It consumes virtually the same amount of power as our 1GB 4870, and yet it's over 10dB louder than the 4870. While the 4870 probably tuned a little too much towards quietness at the cost of heat, the 4890 is tuned in entirely the opposite direction - it gets very loud to the benefit of load temperatures in the 70s (heck, it's the second coolest card under Crysis, beating our otherwise marvelous rev 2 5770).Hmm? Quite a few, actually:
http://www.anandtech.com/video/showdoc.aspx?i=3783&p=19
Their objective dBA reading for the GTX480 (64.1) was higher than that of the 5970 (63.6), which is a dual-GPU card.
db is never measured right next to the device , I can't remember the exact distance but I think the standard is 1 meter from the source. Cases can amplify or cut the noise too. 60db is about the level that people talk at in a room . I hope this isn't a card that requires people to do things like" I got a new gtx480", "what ?" , "I SAID I GOT A NEW GTX 480!"
So, um, now its been rebunked?
I can hear 480 SLI downstairs in my kitchen while it is running upstairs in my office. Doing some more single card testing now.![]()
Don't even need graphs and numbers. I recall heatpipes judding from the stock 480. To me that speaks volumes about how much heat and thus, noise that thing generates.
