Meghan54
Why the whining about needing 42 amps on the +12V rail? You understand this is a system wide recommendation, right? Just like the 600W recommendation is also a system wide suggestion, right?
If you think you need 42A on one rail just to supply the video card, that'd be just over 500W, just for the card.
No, a good little 650W multi railed power supply would run that card well. Take the Antec Earthwatts 650. Three +12V rails, 22A, 22A, 25A on them. The last listed is dedicated to the pair of PCI-e connectors it has. So those two connectors have available to them 25A, or 300W. That's 300W through the PCI-e connectors to the video card, and that doesn't include the 75W available through the PCI-e slot. So that's 375W available to it.
You cannot tell me that this card will require more than 375W to function.....should be more like 300W to gain certification for it. So, a half decently constructed multiple railed power supply should be more than capable to run it.
