no, the checkmark is grayed out and you can not select it.
I'm using 3.02 on a 690 and I still have the framerate counter....does a "clean" reinstallation of precision x fix it?
Anyway, this driver:
Much improved phsyx performance in Batman: AC. With Physx high (which I used previously) framerates are easily 20-25 fps higher.
Witcher 2 is supposed to be improved in the patch notes, but I get stuttering and worse GPU utilization in SLI with this driver. FPS down a bit everywhere
Framerate hitching still there, unless you select "prefer maximum performance" instead of "adaptive" in the CP. Changing this setting fixes the vsync stutter in most games that i've tested
Diablo 3 still has slight hitching, but max performance seemed to help greatly
Shogun 2 has greatly improved performance
WoW hitching is gone now (it was REALLY bad before -- it would dip to 40 fps in some areas for no apparent reason, but the game is 200 fps with vsync off in the same spot..lol...anyway its fixed.)
The issue that I mention above for WoW, diablo 3 still had it last I tested. Which doesn't make sense because performance is as expected with vsync off, but weird drops below 60 with it on.
BF3 seems about the same, I don't keep my eye glued to the FPS counter when i'm blasting people though.
Crysis 2 about the same.
Bulletstorm seems slightly worse, I could be crazy though...I don't keep a hawkeye on the fps counter when i'm playing..
Thats all I tested so far....oh...3dmark G score was slightly higher. I'll wait until wednesday before posting it though
