HeroOfPellinor
- Dec 27, 2001
- 11,272
- 1
- 0
Originally posted by: Duddy
"Your hard drive is essentially fried."
LULZ!!! Makes me feel smarter![]()
No, I think he actually said that the operating system was fried. Which is like 10x funnier.
Originally posted by: GTaudiophile
I'm sorry, but the averager person does not accidentally change setting X deep in the BIOS...most never even see the "Press DEL to Enter Setup" text on boot!
That just was not a "real world" problem they created for those stores to solve IMO.
Originally posted by: CZroe
By not answering truthfully and saying that they were messing around in the BIOS, there's no way it would take 30 seconds to fix because that WOULDN'T be the most likely cause. Being coy is not a good thing for a customer that wants it fixed.
Originally posted by: jpeyton
What kind of half-assed tech doesn't do a 30 second check of the BIOS before doing a full HD scan or reformat/reinstall?
Quit making excuses for these buffoons.
Have you ever been a PC tech or something? You seem awfully crazy about this. The test was dumb, and you're comments are dumb.
It was a rather elementary problem.
For example, the guy said the OS was fried? If he had attempted an install or a repair via Windows CD, he would've absolutely known that the hard drive wasn't being detected because Windows wouldn't have picked it up.
That calls for an instant look at the computer to see:
-If a RAID controller is installed and the HD is hooked up to it
-If there's a setting incorrect in the BIOS with the HD (IDE/SATA/RAID) configuration.
-Cables/jumpers are properly connected/set
It's a laptop! There is no RAID card. He simply changed the boot settings. You could probably easily see that a hard drive was there from the boot process. You would then have to say, either something is wrong with the BIOS boot up or you need to check the OS. You can do both in one step, go into the BIOS to set to boot off the CD (checked) and then boot off the CD (checked). Then you can go from there. If I do not see a hard drive from the boot process, well it's time to check the BIOS and then har drives connection. I just think no work was done by Firedog and the Best Buy guy was just trying to push more services because he's stupid for taking the hard drive out without using their OWN diagnostic tools. Geek Squad has some nice tools. I know a guy who works there, and he's better than the dumbass they found.
But you were aserting no hard drive was found. You don't need ot go into the BIOS to see if a hard drive is present. Can you not read the boot up messages? If not, then yeah you need to hit the BIOS up. I am saying from what I saw, it looked like a boot setting change.
Yes the hard drive would have been detected! It would maybe boot the CD(depend on if the CD was set to boot). Had he attempted to boot from the CD, he would either be successful or he would need to go in the BIOS to change it. If it did boot up, it would find the hard drive and the windows installation. Only if they had turned off the controller, would he not be able to use the Recoevery Console from the CD.
*edit*
I'll give you RAID but SCSI isn't as common any more and it's possible. I had issues at a previous job with some new laptops on SATA support. Had to make a special image for them.
That could happen if what you were doing is trying to hook up the drive using a USB -> 2.5" IDE header/converter since there are drives drawing more than the standard USB spec of 500mA on the 5V rail. Still, t3h fail for not knowing thatOriginally posted by: mcmilljb
Geek Squad took it out. You don't do that at first. Check the POST message for a hard drive or look at the BIOS. He couldn't even get the hard drive work on his computer. He was hearing some "clicking". He shouldn't even be allowed to touch a computer.
