Originally posted by: Roger
Who ever the hell you are Munchies go back to bagging groceries for a living, you are not cutting it as a auto tech.
UHHH NO. Thats the bigeest load of BS if heard in a while. And I should know considering I build engines for my income. Run it dry it wont hurt nuffin. It will just sputter a bit, cant hurt
Its going to not makea diff. Ever hear of wtaer injection on gas engines?
I never heard so much BS in one thread from one member before.
These are the facts ;
All fuel injected vehicles from the factory have in the tank fuel pumps, these pumps are cooled by the fuel passing through them, the fuel pressure regulator on the fuel rail returns unused fuel from the engine back to the tank, this serves two functions, one, it acts as a reserve of fuel for full throttle and full load conditions, two, it acts to cool the fuel pump, the pump is continually pumping fuel from the tank to the engine and back to the tank again.
Most fuel pick ups inside the tank are raised a half inch of the bottom of the tank to prevent debris from being picked up but this is not to say that it cannot make it's way into your fuel system.
Running the tank dry is detrimental to the entire fuel system and you engine in the following ways ;
Condensation will form on the walls of the tank, this water will find it's way to the fuel system, water is damaging to fuel injectors because it is corrosive, also the ECM will try to correct a lean condition that is present because of the water, in newer vehicles with OBD II this will trip the check engine light, not to mention rusting the tank, fuel lines and fuel rail(s).
Water in a carb is not as bad but water will naturally go straight to the bottom of the fuel bowl, if the main metering jet(s) are raised slightly above the floor of the bowl then corrosion will occur inside the carb, incidentally all carbs have accelerator pump feed(s) at fuel bowl level so water will find it's way into the accelerator pump well thus corroding it.
While your at it, go back to school and learn how to spell.
