Hey Waggy, come to Connecticut
I give certain members some slack, Conjur happens to be one of them
I give certain members some slack, Conjur happens to be one of them![]()
Here's a question for Roger: Since liquid sloshes around a container of a moving object, if your tank gets low, is it possible your pump might suck some air if you take a corner while low on fuel? If so, could this damage anything?
Originally posted by: Mwilding
Originally posted by: Munchies
UHHH NO. Thats the bigeest load of BS if heard in a while. And I should know considering I build engines for my income. Run it dry it wont hurt nuffin. It will just sputter a bit, cant hurt.
respeckicustoms.com
http://respeckicustoms.com/
Wow - greatest display of html prowess in the history of html prowess...
Originally posted by: Chaotic42
Well, I'm not a carologist, but it seems like all of the various water, bits of crap, and other impurities would settle to the bottom of the tank. On a full tank, they make up like 1% of your tank. On an almost empty tank, it would be 50%.
It's like drinking from a big sink of water with eggs and bits of food at the bottom. You're better off if it's full.
If the water is .5" above the crap, it's probably gross.![]()
respeckiOriginally posted by: MysticLlama
respeckicustoms.com
I especially like how the logo graphics at the top are spelled differently than the domain name and the text description. I wonder which it really is.
respeckicustoms.com
its spelled wrong because I am not done with it obviosly, and havent paid the man yet. Smartass
So Munchies, are you still going to stick to your "water is ok in your fuel system" theory ?
So Munchies, are you still going to stick to your "water is ok in your fuel system" theory along with the "fuel pumps do not require cooling" theory ?
You do realise that an electric fuel pump running dry (i.e. without fuel running through it) will quickly heat up to well above ambient temperature? The water in a radiator is well above ambient temperature while the engine is running but it still provides cooling. A substance does not need to be below ambient temperature to function as a coolant. The gasoline running through a fule pump most definitely does function as a coolant.Originally posted by: Munchies
just for the hell of it, I stuck a thermometer in my tank a few minutes ago, and it measured 1/2 degree lower than the ambient temp outside.
Negative, on fuel injected vehicles, the fuel pump sits inside a small well on the bottom of the gas tank thus preventing the pump from sucking air when the level get's low.
Water in large ammounts of course is not good, some condensation in the tank over time (decades) might rust some stuff, and clog lines with rust, but other than that no. I have run a water/alcohol jet system using a carb baseplate on a 19:1 race engine, with great results. Fuel pumps do require cooling,but the gas doesnt do it in my truck. I happen to have in in tank system on my !CARB'D! scout, and just for the hell of it, I stuck a thermometer in my tank a few minutes ago, and it measured 1/2 degree lower than the ambient temp outside.
15 overhauls a week of WHAT? Engines? You can't overhaul 15 engines a week even if you're just doing the old backyard rings/bearings/gaskets rebuild.Originally posted by: Munchies
Not too bad considering its only 20 bux for the whole thing im overloaded with work as it is, I really dont care about my site, I get about 15 overhauls a week. Then I balance my own project, coupled with a few high performance, CNC digitizing jobs. Its crazy as hell out here. My site is just a means of communicating to my buddies over at binderbulletin.org
Lawnmowers. :laugh:Originally posted by: Pacfanweb
Much less perform a high performance overhaul, which is much more work.
I certainly hope you're talking about overhauling websites or something.
Originally posted by: DivideBYZero
Originally posted by: Taggart
I've read that the fuel acts as a coolant for the gas pump in your car. Staying below half a tank on a regular basis will shorten the life of your gas pump, or might cause it to burn out on you.
Is this post real?
LMAO!
