Originally posted by: Sabot
Originally posted by: FrozenCanadian
Depends where you live. I'm on Canada/US border Near NY. I paid well over $1k this winter so if your in a northern state $80 a month is too low. If you are in a northern state then a 1K bill is acceptable (if you ignore there stupidity). If you are in a southern state then fight it.
I'm in Toronto, so i guess it makes sense.
Originally posted by: MrBond
When I was in undergrad, we rented an old house near campus with natural gas heating. It wasn't uncommon for that to happen to us too, we'd get regular looking bills, then one month it'd be insane.
I'm so glad I moved out. The house was impossible to heat, we kept it at 60 most of the time and put that window-sealing plastic on all the windows. The front door leaked so bad we had to seal it off entirely with that clear plastic and use the back door.
Then in the winter, since there was no attic ventillaton, the heat would just build up in the house and not go anywhere, so the upstairs would be insanely hot. My room was in the basement and after long periods of hot weather, it'd be the same temperature in there as the rest of the house (not cool like a basement usually is). We'd run electic bills of $200+ each month in the summer because we had window+ceiling fans going in every room 24x7.
I'll never live in an old house like that again if I can help it. New construction rocks!
Originally posted by: KLin
Damn, your guys' gas bills look like my electric bill during the summer time. Well maybe not as much because I'm in an apartment
Originally posted by: Syringer
I live in Los Angeles and I'm not sure if my heater even works
Doesn't equal billing work out to be more though? I mean you pay a set rate each month so this doesn't happen, but wouldn't that add up to be more?
