Zenmervolt
Elite member
Originally posted by: Arkaign
From a manufacturing standpoint, I don't see how FWD would be cheaper than RWD to make. The parts on a standard live-axle RWD car should be cheaper, as they are much simpler in design, instead of the differential being stuffed up there by the motor/tranny with CV axles poking out. I think that's why cheap 4-cylinder manual-tranny rwd pickups are so cheap.
Manufacturing and space efficiency mainly. It's much easier to just dump the whole engine/transaxle assembly into one end of the car all in one shot than to throw in a RWD drivetrain. Especially in a unibody chassis.
The little 4-cylinder pickups are cheap because they are body-on-frame and very easy to assemble. You can put the whole chassis together (essentially) with the engine and all running gear and then just bolt the body on around it. Can't do that with a unibody car. FWD also allows more interior volume for a given exterior size when compared to RWD. So the companies can build a car that has more room inside while being smaller outside (meaning they use less steel to build the car, that it can be lighter, which means lighter-duty components, costs savings in many places)
FWD is definitely overall cheaper for the car companies, just because of some of the economies that it allows.
ZV
