Fvcking spiders...
Kadarin
44,296
16
Originally posted by: Crazyfool
I get weird bites all the time... I guess they must be spider bites as the skeeters aren't really in bloom yet.
Can't wait to make my move to So CA soon. Much easier to deal with spiders/skeeters there. ;)
Yeah, one difference between CA and back east is that the bugs back there are positively malevolent. Even common flies will bite you through your clothing...
Dec 4, 2002
18,211
Originally posted by: Sukhoi
Ok this is fvcking WEIRD. I can't recall seeing a spider in the apartment the two years I've lived here. As I'm reading this thread I see a spider running across the wall right above my pillow. I did manage to kill it after some strategery and a staredown.
:D
Stumps
7,125
Originally posted by: minendo
...Wouldn't mind them if they weren't deadly.
Walked out on the front porch earlier and spotted at least 10 brown recluses(sp?) out there. Guess I need to stay inside.
come and live in Australia...then you will realise that where you live isn't so bad after all.
every single day i see dozens of redbacks or white tails(both are extremly dangerous, especially white tails) around where I live, I get them exterminated on to have ten times as many the next day...then add in all of the brown snakes, ticks, scorpions and centipedes...and the worst of all the obnoxious GF(that one can annoy you to death in seconds)
LiquidImpulse
2,062
yea, i feel australia is the most dangerous continent to live on. snakes,spiders,sharks,scorpions,the works.
dartworth
15,201
10
First Aid
If bitten, remain calm, and immediately seek medical attention (contact your physician, hospital and/or poison control center). Apply an ice pack directly to the bite area to relieve swelling and pain. Collect the spider (even a mangled specimen has diagnostic value), if possible, for positive identification by a spider expert. A plastic bag, small jar, or pill vial is useful and no preservative is necessary, but rubbing alcohol helps to preserve the spider.
An effective commercial antivenin is not available. The surgical removal of tissue was once standard procedure, but now this is thought to slow down wound healing. Some physicians administer high doses of cortisone-type hormones to combat hemolysis and other systemic complications. Treatment with oral dapsone (an antibiotic used mainly for leprosy) has been suggested to reduce the degree of tissue damage. However, an effective therapy has not yet been found in controlled studies.
Control
Control of indoor infestations of the brown recluse spider can take a long time (6 months or more) and can be difficult because humans have a very low tolerance for this pest, it tends to be widely dispersed within infested buildings, and it seeks secluded sites. Control of spiders, including the brown recluse, is best achieved by following an integrated pest management (IPM) approach. IPM involves using multiple approaches such as preventive measures, exclusion, sanitation, trapping, and chemical treatment when necessary.
Preventing spider bites
* Shake out clothing and shoes before getting dressed.
* Inspect bedding and towels before use.
* Wear gloves when handling firewood, lumber, and rocks (be sure to inspect the gloves for spiders before putting them on).
* Remove bedskirts and storage boxes from underneath beds. Move the bed away from the wall.
* Exercise care when handling cardboard boxes (recluse spiders often are found in the space under folded cardboard flaps).
Exclusion
* Install tight-fitting screens on windows and doors; also install door sweeps.
* Seal or caulk cracks and crevices where spiders can enter the house.
* Install yellow or sodium vapor light bulbs outdoors since these attract fewer insects for spiders to feed upon.
* Tape the edges of cardboard boxes to prevent spider entry.
* Use plastic bags (sealed) to store loose items in the garage, basement, and attic.
Sanitation
* Remove trash, old boxes, old clothing, wood piles, rock piles, and other unwanted items.
* Eliminate clutter in closets, basements, attics, garages, and outbuildings.
* Do not stack wood against the house.
* Clean up dead insects that the brown recluse spider can feed on.
Non-chemical control
* Use sticky traps or glueboards to capture spiders.
* Dust and vacuum thoroughly to remove spiders, webs, and egg sacs (dispose of the vacuum bag in a container outdoors).
* Use a rolled up newspaper or fly swatter to kill individual spiders.
Insecticides
There are many labeled pesticides for spider control. Some are labeled for homeowner use, while others are labeled only for the licensed, certified pesticide applicator. It would be prudent to enlist the services of a professional pest management company when dealing with an indoor infestation of the brown recluse spider.
Research indicates that recently developed pyrethroids (e.g., cyfluthrin, cypermethrin, etc.) are particularly effective against brown recluse spiders. Wettable powders and microencapsuled "slow-release" formulations of these chemicals provide residual activity and are preferable to using emulsion-type sprays. Insecticide treatments should be applied so that the chemical contacts as many spiders and webs as possible. Residual liquid sprays should be applied to the outside perimeter of the home (including under eaves, patios, and decks; behind window shutters), baseboards, undisturbed corners, and other suspected spider harborages. Residual dusts should be applied to voids and inaccessible areas where spiders may hide. Aerosol flushing agents such as pyrethrins, though ineffective by themselves in providing control, can cause spiders to move about so that they contact treated surfaces.
Stumps
7,125
Originally posted by: dartworth
First Aid
Control
Exclusion
Sanitation
Insecticides
OK...explain to me the procedure for an Australian White tail spider bite then?
If you use google to look it up take note at the pictures of the bites from that nasty little (most are less than 2cm's)spider
IGBT
17,976
141
..there the ones I worry about..I keep a few aligator lizards in the front room to take care of spyders and other invaders. always fun to see the aligators patroling the window sills or climbing the walls to take out a spider web in progress. ;)
Descartes
13,968
I call shens. No way were they the BRS. The BRS doesn't just casually hang out in open spaces, and certainly not a porch that likely gets a fair amount of sunlight. They like dark, fairly dry, quiet environments. Take a picture, because you're probably seeing another brown spider. A lot of people mistake other species for the BRS.
FWIW, I used to live in a townhome where I was infested with them. They were confirmed BRS. You find them in closets, shoes, under beds, boxes, etc., not on your front porch our out in the open.
SVT Cobra
13,264
Time to put on the Ghostbuster suit, grab a 12 gage shotgun, turn up some Drowning Pools-Bodies, and go hunting. That's what I would do, because if I saw a brown recluse, even just one near my house, I would be moving soon anyway so I wouldn't care about shooting out the walls.
Quasmo
9,630
you should kill them and then tell us how you killed them, by finishing the story. Thanks
Sukhoi
15,350
:D
Oh it was a staredown alright. As I went to smash the spider it dropped off the wall onto the top edge of my bed, which is against the wall but had about 1/2" of clearance. We both stood there a good 30 seconds without moving. Then it blinked its multiple eyes and took off for the crack of space by the wall. I grabbed my bed, slammed it forward, and caused the spider to come back out onto the top of the bed. From there I managed to sweep it off onto the floor, where I destroyed it. Total domination.
xSauronx
19,582
4
its the government secretly trying to kill you for telling everyone they shot down flight 93 ;)
