Gikaseixas
- Jul 1, 2004
- 2,836
- 218
- 106
Will the dual fiji have two pumps? or a single, bigger pump for the two gpu's?? Bigger rad most likely right? Louder?
Might bump it to a 140mm RAD but I would expect everything else the same (2 pumps etc)
I bet they'll take the 295x2 approach and use the same size rad and pump configuration, letting the dies go higher in temperature in order to keep fan noise reasonably low
I would expect them to keep the 120mm single radiator. Pretty much every standard case made lately has a 120mm fan location somewhere within reach of the GPU. 140mm rads would restrict it much more. Not worth it for an extra 35% radiator area when you could just run at higher temps or higher fan speed.
Has anyone confirmed the fan specs yet?
It looked awfully close to my Scythe Gentle Typhoon AP14s, but I'm sure they used a higher RPM variant...
It's not so much just needing the extra fan spot, it's the increased performance you'll get at higher flow rates, and the lower coolant temps (and/or quieter operation) that come with more radiating surface. There's only so much you can do on the temperature/noise curve with a single 120mm rad.
I don't see any reason to worry about removing the stock pump/block though. Pumps in series are used commonly to provide extra head pressure and add redundancy, there probably won't be a problem leaving it in. Even if you disconnect it, a disconnected pump adds minimal extra restriction. The bigger issue would be if the cooling on the VRMs isn't great, but it would have to be pretty bad to make you fork out $120 for a full coverage block unless you're going for a really pretty system.
Edit: Having a disconnected pump in the loop adds almost no restriction at standard 1-1.5GPM flow rates.
How often do people with a custom loop make use of the rear 120/140mm spot? I usually see bigger rads up top or in front rather than that space, which often carries an exhaust if anything.
Nice find, I learned something new today. I never brushed on on dual pumps, never had the need. Makes it a little more interesting for me, but I bet the Fury barbs/hose are small, like 1/4".
Check my post and picture on the previous page. Coolermaster's making the AOI, and the tubing looks very similarly proportioned to the Seidon 120M pictured on the left. I pulled it off and it was 1/4" tubing.
Yeah, that wouldn't work well for someone with a 1/2" system. This looks restrictive.
