waggy
I can honestly say that everyone I have sex with always smokes after!
Then again I am the furnace operator at the crematorium.
/facepalm
lol
My house is 1500 sqft (main level) with about 1000 sqft basement (partially finished, heated).
The furnace is about 50,000 btu which seems small to me...it looks small too. It is a newer model, high efficiency furnace. Haven't been able to pinpoint a date exactly, but I'd say it was installed in the early to mid 90s.
Anyway to tell if the furnace is the correct size? If so, would having a furnace that is too small make it less efficient? Would it cost more to run or does it just mean it would run longer but heat the same?
Recheck your settings. Also the type of heating system (hot water baseboard or hot air) and wether it is a newer high efficiency furnace will have to use the correct settings.
Set to 5 if you have gas or oil furnace ... this would be for normal, old hot air furnace
Set to 9 if you have electric furnace .. not many homes have this type
Set to 3 if you have hot water or high efficiency furnace .. hot water baseboard heat or new high efficiency furnace
Set to 1 if you have gas/oil steam or gravity system ... only used if you have steam radiators found in many very older homes
Note you can check the nameplate on the furnace. If it is within say 4 years or so old and has a rating of 80% or higher, it is a high efficiency type of unit.
What the hell is a furnace?
A ton is about 200,000 BTU. So your unit isn't even 1/2 ton, a small unit.
Seems to me it'd be more efficient to try and keep at a constant temperature rather than losing all that heat during the day and trying to make it up in the evening.
Tonnage is associated with refrigeration and comes from number of tons of ice that could be made in a 24 hour period. 12,000 btu/hr is one ton.
A common size for a household AC unit is three tons - 36,000 btu/hr.
Heating usually is much higher whereas a home may need three tons of AC the furnace may have 100,000 btu/hr. That is actually the INPUT so if the furnace is 80% efficient the actual heat directed into the home would be 80,000 btu/hr.
To answer your other question, yes, it saves energy. Your house loses energy at a rate proportional to the difference in temperature between indoors and outside.
sounds like its short cycling, The last time mine did that was because it was overheating and shutting off prematurely. I had a repairman come out and test it. He cleaned the units gas vents and that fixed the problem.
I have also heard that some HEPA filters will cause some units to short cycle because of over heating.
If its an older unit it may just need cleaned.
Look like a great project, but making things more unreliable by complicating things. Most new commercial/industrial HVAC system are now centralize control via the internet, and I haven't seen anyone apply this method for residential dwelling (even on 20+ millions dollar house/structural only).That's a good point too. It may be the furnace itself.
OP: When the furnace stops, is the temperature at what it should be? Also, you should hear the relay in the thermostat go click for going on or off. Does this correspond with the furnace going on or off, or is the thermostat always in the on position and the furnace still going on/off?
Speaking of thermostats, this is a little project I've been working on. More blog entries after that one. Overkill thermostat ftw.
:biggrin:Its like hell but only smaller
Function 1
0 Heating & cooling: Gas, oil or electric heating with central air conditioning.
1 Heat pump: Outside compressor provides both heating and cooling without backup or auxiliary heat.
2 Heating only: Gas, oil or electric heating without central air conditioning.
3 Heating only with fan: Gas, oil or electric heating without central air conditioning. (Use this setting if you could turn the fan on and off with a fan switch on your old thermostat.)
4 Cool only: Central air conditioning only.
5 Heat Pump: Outside compressor provides both heating and cooling with backup or auxiliary heating.
6 Heat/Cool Multiple Stages: Two heat stages (wires on W and W2), two cooling stages (wires on Y and Y2).
7 Heat/Cool Multiple Stages: Two heat stages (wires on W and W2), one cooling stage (wire on Y).
8 Heat/Cool Multiple Stages: One heat stage (wire on W), two cooling stages (wires on Y and Y2).
Function 3
0 Gas or oil heat: Use this setting if you have a gas or oil heating system (system controls fan operation).
1 Electric heat: Use this setting if you have an electric heating system (thermostat controls fan operation).
Function 5
5 Gas or oil furnace: Use this setting if you have a standard gas or oil furnace that is less than 90% efficient.
9 Electric furnace: Use this setting if you have any type of electric heating system.
3 Hot water or high-efficiency furnace: Use this setting if you have a hot water system or a gas furnace of greater than 90% efficiency.
1 Gas/oil steam or gravity system: Use this setting if you have a steam or gravity heat system.
