Originally posted by: DerekWilson
can you link a screenshot of the display issues other than the "forum below sidebar" issue?Originally posted by: Anubis
none of the themes display correctly in opera other then the default one ( specificially the side bar)
there is no DARK theme, where ylou have a Black or Grey background with white text
the currently logged in users really needs to be turned off
placement of Buddies and catagories pannels need to be switched
names for forums and threads need to stop being truncated
we've already got the buddies and category list swap and the truncation issue up there. we've asked for a dark, low contrast theme, but i'll make a note of a light on dark theme request.
we're not removing the online users box.
Originally posted by: Zee
them bottom of the webpage sometimes doesnt come up or show up over half the page numbers. both in ie7 and ff just shows big gray block with the ad.
Originally posted by: SVT Cobra
Also, any way that the buttons could be regular links and not java so we could middle mouse click em for tabs, or would that be asking too much?
It has? I must be missing something.... at least with the page number buttons.Originally posted by: SVT Cobra
what buttons?
Never mind it has already been fixed.
In multi-page threads i would load the 2nd page while reading the 1st page, and so on. Saves a bit of time being on dial-up.
You're right, but when I went to go look forgot what buttons it was. Yes these were the ones I meant.
Thanks for the info, that clears things upOriginally posted by: DerekWilson
Tegeril,
In the past, our web developer has modified FuseTalk to suite our needs or fix our bugs. This voided our support contract with FuseTalk. In part, the move to FT 3.0 was to get us on FuseTalk supported code. We are unable to fix bugs ourselves at this point.
To more directly answer the question, "this" was an update that FuseTalk submitted to us as a patch. They are already working on a second patch to address a second set of less critical errors ... this first patch fixed a lot of behind the scenes issues and admin/mod tools.
Originally posted by: Bryophyte
Preview seems to only work half of the time. You can manually fix the quotes tags, but if you edit the post later, it reverts to the buggered tags and you have to manually fix them all over again.
Originally posted by: Shawn
Language censor hasn't been fixed. It just doesn't work at all now.![]()
<div class="FTQUOTE"><begin quote>Originally posted by: Shawn
Language censor hasn't been fixed. It just doesn't work at all now.</end quote></div>
it works ... replaces words we have in our list with a string of *
"Ooops! You encountered an error, we have let the webmaster know about the problem." happens a lot and shouldn't.
