Couple of notes on these new NetMD players. One, I haven't used them yet, so don't assume everything I say holds true for these newer units.
The Sharp review I've read of their NetMD player was less than spectacular. It sounds like the Sony unit (That being the NZ1 not the cheaper MZ-N505) is better overall with the Sharp winning out for live recordings. I've used one of Sharp's older non-MDLP units and I really preferred its menuing system and overall sound (bass is much more pronounced and overall better sound than the Sony MZ-R900, also the amp on the Sharp portable was stronger than the amp for the Sony MZ-R900). From what I've read on the Sharp NetMD unit, the same holds true still. The Sharp's major drawback is it can only record in 1x at standard MD, 8x at LP2, and 16x at LP4 where as the Sony claims to be able to do 4x at standard MD (dont know if this is really accurate according to reviews I've read); 16x at LP2, and 32x at LP4.
Now personally I'm no audiophile, and I don't own spectacular headphones or anything (my best set of headphones is the $80 Sony MDR-E888LP)... But I've recorded audio from a CD onto an MD at LP2 and the quality is very very good. I'm sure if I listened carefully I could tell the difference between the source and the LP2 recording, but when I'm on the go (and I'm guessing thats what most of you guys use your portable players for) I can't hear the slightest difference between LP2 and the original CD source. LP4 is noticeably worse, but LP2 is pretty good. And being able to hold 160 minutes of audio on 1 disc, roughly 2.5 hours is pretty damned good if you ask me. Especially when you consider that you can easily hold 4 MDs in your pocket or even more if you carry around a backpack like I do. Don't assume that 132Kbps MD is going to sound almost like a 128Kbps MP3. ATRAC3 is a completely different compression scheme than MP3 and just like Microsoft claims a 64Kbps WMP file can sound as good as a 128Kbps MP3 file ... I believe a 132Kbps ATRAC3 recording can and DOES sound a lot better than MP3 at 128Kbps or even MP3 at 192Kbps for certain recordings. This is from my personal tests using a Sony MZ-R900 and a CD source (all digital, no analog recording). I have nothing against MP3 though, I have tons of my CDs encoded in MP3 on my computer and on CD for my MP3-CD player in the car. But the NetMD solution is really nice if you want a small footprint removable media-type player/recorder. For college students on the go, this is especially nice since you can easily fit the MD player in your pocket and a couple of discs. Just trying to help remove some of the confusion for anyone who is thinking of buying a NetMD unit and thinking it may sound crappy at "only" 132Kbps...
Anyways, can't wait to see some 2nd generation NetMD units. If Sharp can produce a good unit, I may just have to jump on the NetMD bandwagon
