I am looking at the bios and there is an option to change FSB.
Also look at http://www.ocworkbench.com/2006/ecs/P4M800PRO-M-V2.0/g4.htm
Originally posted by: atlr
Originally posted by: jpeyton
Using electrical tape to isolate a pin would be used to pull it from low to high, which is the opposite of what we're trying to accomplish, right? Correct me if I'm wrong.
J, I believe that you are correct.
You insulate a pad to draw it High and ground a pad to Vss to draw it Low.
Originally posted by: highwire
Whee!
I did a BSEL mod on this combo. With stock settings in the bios, that got me 2.4Ghz. Bumped the FSB to 300, and its setting there at 2.7Ghz like it is nothing. How about that for a low bucks OC? I guess the E6300 combo can go back to Mr. Fry's store.
Thanks Zap for mentioning the BSEL thing.
Now a question: How can I tell what speed the PCI, etc is running? I tried to get tech info out of Via on this chipset, but they seem to be a bit anal about it. I don't want to run some screwy freqs on the rest of the board. I know some divider setting automatically come in at various points.
All in all, I think I got what I wanted out of this combo.
Run <a target=_blank class=ftalternatingbarlinklarge href="http://www.sisoftware.co.uk/index.html?dir=dload&location=sware_dl_3264&langx=en&a=Originally posted by: highwireNow a question: How can I tell what speed the PCI, etc is running?
No problem. Too bad I got the specifics wrong.Harkens back to the days that I was overclocking socket 370 and 478 chips on non-overclockable motherboards.
Now, since at least 1 of these boards has proven it can run at 1.2 ghz FSB, someone should do it right with a BIOS hack.
Originally posted by: mhartsel
OK.....I think that I am almost there, but wanted to clarify a couple of things first.
1st- BSEL 1 needs to be isolated so that there is no actual connection from the motherboard to the CPU ???
2nd- BSEL 1 needs to be connected to VSS which is 3 Pins above it....So in affect connecting H30 to L30 on the motherboard side....which in affect tells it to go from FSB of 200 to FSB of 266 ???
I see in some of the pictures posted of the mod that it appears that BSEL 2 has been isolated...does this need to be isolated or can it be left open ????
The motherboard is fine. It's pathetic you power users and overclockers think the computing world revolves around you.Originally posted by: smthmlk
not a good deal, considering the motherboard is worth $0.00. You can pick up an e4300 minus the crap motherboard from newegg for $115The one-day sale a while back had the same proc for $99+crapmobo didn't it? I guess so, according to the previous poster
