Formatting Hard drive with a Converter
No big deal.
You really want to "Wipe" (ie, write zeros) to the drive, not just format.
For a one time operation, I would substitute the drive into the laptop (dont bother screwing it in place, just support it as needed with a cardboard shim) , boot up a Windows 98/ME recovery disk with free program "Wipe" added on it, then clear the drive. Substitute the next drive to be cleared and do the same, etc.
Otherwise, buy an external enclosure and do the job, but you may have to first boot up in an operating system/OS then execute the "Wipe" from command line.
The first option has advantages that it is least expensive plus no way you can screw up accidentally cleaning the wrong drive.
It wont go into it. My computer doesn't have the 4 little pins you see in the picture to the right. You know what I mean? It can't be inserted into my computer that I have now. That's Why I was looking into getting a converter.
No big deal.
Could you recommend a converter for this hard drive?
No big deal.
Thank you! I did get it to go in after all. Just used Dban and wiped the drive. Thanks Alot! 🙂
the four pins on the side arent required for standard operation or installation.
i would put each drive in, one at a time, and use DBAN to wipe. autonuke option should be fine.
just ensure you dont have any other disks installed that have data you wanna keep, DBAN will wipe anything it sees.
