dartworth
Originally posted by: filmmaker
You can always get a good sized ring at Kay Jewelers for @ $2000
LOL
Originally posted by: bozack
Originally posted by: Marlin1975
"Man made ones are made unser controled conditions. Also why don't you go see the man made ones and also read about them. Dealers can't tell the diff. between the man made ones and regular ones with out special equipment.
But maybe you are slow I am sorry, I didn't know every day common sense was hard for you to handle."
Right Marlin and here you are contradicting yourself, on one hand you say that Man made diamonds are superior because they are created in a controlled environment to exacting specifications, yet on the other point you say that dealers cannot tell the difference between man made and naturally formed diamonds...so if dealers cannot tell the difference then how can you?? and then you finish up with saying that a difference can be detected with "special equipment" which would lead readers to believe that there are inherent differences between the two items, they are just difficult to find. Are you saying they are "better" simply because they are cheaper and look the same to the naked/untrained eye?...specifics please, seems like attention to detail really isn't your forte which is also illustrated by your lack of spelling prowess, unless of course unser is a new word that I have to hear about.
Originally posted by: bernse
Be careful.
THEY = Diamond Industry.
They are not your friends.
Buy what you can afford. IMHO, 2 months salary is too much.
Thats the point you idiot. A $1000 natural diamond will be probable half that or less if you get the same type in mand made form. So a $500 natural diamond will come no where near the quality of a $500 man made one. Did I speel it out S-L-O-W enough for ya??
To those suggesting Canadien diamonds, while they are a way to avoid buying from Debeers they are not nearly as inexpensive as people had hoped they will be...basically they are the same price as buying from Debeers so the only redemption in buying them is that you avoid the moral implications of buying from the cartel....
Originally posted by: Davegod75
When they say two months salary do they mean before or after taxes..... 😱
everything i like is like 5,500 plus..and that's just the diamond
of course that's
cut = ideal
color = F or higher
clarity = VVS1 or higher
carat = .6 - .1
polish/symmery = VG/VG or higher
Am I too picky?..if so what is the thing you can get lower of without sacraficing look😱
Agreed.cut = ideal
Anything above H is a waste of money.color = F or higher
Anything above VS2 will never be seen with the naked eye.clarity = VVS1 or higher
.6 to .1???? Is that 1.6 to 2.1? For all the research I did, the conclusion that I came up with was to get an H, VS2, ideal cut stone. I wanted something that was above a carat, but it really depends on your budget. If you are looking for those C's, then all you really need to do is find stones that meet those 3, and then pick the size that fits within your budget.carat = .6 - .1
Agreed.polish/symmery = VG/VG or higher
ColorWhat do the color/clarity/etc ratings mean and what is the extent of the scale?
There are many many different types of certs available. The 3 most popular are the EGL, GIA, and AGS certs. The EGL certs are supposedly a little less accurate then the GIA, and provide less information. Any cert you get should at least have the clarity and weight of the stone. They will also contain measurements of the cut, and usually an image showing any extra facets and the locations of inclusions in the stone. There are some "extras", such as laser inscription of cert number, etc. which you can research on your own.What kind of certs are available and what exactly do they provide?
Not sure about this one.Is there a substantial market for used diamonds?
Google is your friend. Personally, I'm not really interested.... so you can research it if you are.Does anyone have a link to DeBeers' list of heinous atrocities that have been mentioned?
Nowhere that I know of. The market is very small right now, you would have to go way out of your way to get a manmade stone, and you probably wouldn't save much money as of right now.Where can one purchase man made diamonds?
It's really a judgment call. Personally, I like to have my hands on the stone and the setting before I spend that much, so I would probably go looking at some local family owned shops. It's up to you.After you acquire a stone, where is a good place to go about finding a setting?
Yup.You buy 2 seperate rings, right?
Engagement ring.Which one is the expensive one, the wedding ring or the engagement ring?
Usually, yes.Are they supposed to be a set that are worn together?
Just the engagement ring.When you propose do you have both or just the engagement?
Yes.Does that mean the engagement ring should be the good one?
I don't think they can be the same one, maybe someone knows more than I do around here.Can they even be the same one? I've never really understood this.
Her or her family, IIRC.And how about the guy's ring, the gal buys that right?
Nope.Does the guy get an engagement ring too?
It depends. If you want them to match, then you should buy them as a set. With some engagement settings though, there is a specific wedding band that goes with them. In that case, the whole matching thing goes out the window. There is nothing that says they have to match, so it's pretty much personal preference.Should you shop together for at least the setting so they match?
Originally posted by: BatmanNate
I'm admitedly new to the whole diamond shopping experience and for the sake of those others in the thread that may have questions, I will post them. 🙂
- What do the color/clarity/etc ratings mean and what is the extent of the scale?
I would check out the 4 C's tutorial at http://www.goodoldgold.com
- What kind of certs are available and what exactly do they provide?
The most respected certifications are from the AGS and GIA. They provide documentation of the specs/grades of the diamond. Other labs are sometimes inconsistent in their grading so they are not as respected.
- Is there a substantial market for used diamonds?
Not really. As long as there is demand for diamonds it will always have value. However, if you bought a diamond retail and turned around and sold it on eBay the next day, you'd be awfully lucky to get half of what you paid for it.
- Does anyone have a link to DeBeers' list of heinous atrocities that have been mentioned?
Don't have one handy, but suffice it to say that they're pretty evil. In recent years they have taken steps to eliminate "conflict diamonds" but for years they used them. They are certainly guilty of monopolistic practices such as price fixing that are illegal in the U.S.
- Where can one purchase man made diamonds?
Good luck. The companies using the new CVD technique, Apollo and Gemesis, are only able to make a very small quantity. I don't believe they'll be widely available until next year at the earliest, and even then quantities will likely be very limited.
- After you acquire a stone, where is a good place to go about finding a setting?
All kinds of places will sell settings. I bought mine from the same place as my diamond to make things easier. You can go to a local store, buy from the internet, or have one custom-made.
Also a question on tradition as far as engagement/wedding rings:
You buy 2 seperate rings, right? Which one is the expensive one, the wedding ring or the engagement ring?
The engagement ring is usually the one with the big rock. The wedding ring or band is usually somewhat simpler.
They can be, but they don't have to be. Many people get a set because they think they look better together.
When you propose do you have both or just the engagement? Does that mean the engagement ring should be the good one?
Either way. Typically the woman does not wear the wedding ring until you are actually married so you don't really need it until then.
Yes, some people choose not to have a separate wedding band.
I've never really understood this. I've seen people that just have like a gold band for engagement then a diamond for wedding, some wear both and some only the wedding afterwards.
Sometimes, or you can buy matching wedding bands together, or whatever.
No.
Personal preference, some women like to be surprised, some want to pick everything themselves. Some people want matching wedding bands, some don't care.
Sorry for asking so many dumb questions, but I really am clueless about this stuff. I usually have a pretty level head about spending my money as does she (heh heh) so I'd like to begin my research now so I'll be better off a year or two down the road. Thanks guys! 🙂
Originally posted by: AbsolutDealage
Just spent the cash on a $6k diamond ring for the g/f... or should I say fiance'...
Anyways, that's ~3 months salary after tax, but the ring is amazing looking. I have a family member w/ a tax ID, so I went to a "trade only" jewelry show and got a really nice ring...
1.06 carat premium ideal cut (unbranded H&A), H, VS2... surrounded in a platinum 6-prong setting, w/ 12 princess cut and 20 round cut pave' set stones (totalling about 1.4 carats for the stones on the setting).
I don't know.. I feel pretty broke, but it's worth it when I see her wear it. I should be getting a promotion/big raise towards the end of the year, and that will help me with paying the ring off.
As for the topic:
Agreed.cut = ideal
Also, if you are shopping around locally, I would recommend you get a loupe (probably something like a Belomo) and definately get yourself an Ideal scope. That will get you started.
Is that Ideal Scope any good? Haven't seen that.
Is the Pro model any better than the cheap model?
I think its great personally. It does a really good job at grading the cut... such that I could probably guess at the angle numbers on the cert just by looking at the stone. I ended up getting what is essentially an unbranded Hearts&Arrows because of it.
I'm not really sure about the pro thing, but I think the dome would just be a PITA rather than helping.
You're right, my mistake. 🙂Originally posted by: AbsolutDealage
BigSmooth, IIRC, Gemesis uses a HPHT technique, not CVD.
