daw123
- Aug 30, 2008
- 2,593
- 0
- 0
Originally posted by: LOUISSSSS
so i just got the majority of my parts (minus the CPU Block).
i've just rinsed out the radiator with boiling distilled water about 5 times with one of the times letting the boiling water sit there for about 5 minutes. (is this enough cleaning?
I've also installed the XSPC Top on the MCP355, it was a cinch, lets just hope it works now. I also rinsed out the reservoir with bathwarm distilled water 2 times.
did i need to use vinegar for any of this?
my next step would be to estimate the tubing lengths for each section, then prepare my test loop outside of the case.
when mounting the radiator horizontally on the top of my case, do i NEED to have the barbs pointed downward? just FYI... can i have the barbs pointed upwards?
and how can i tell the difference between the apogee GT's bowing o-ring and the regular o-ring?
You have been a lot more thorough in your cleaning of the components than I was. All I did was ran each component inc. each section of tubing under the mains fed cold water tap for a few minutes. The idea being any debris within the components (through manufacture, handling, etc.) would be flushed out. Impurities within the tubing and components will be dealt with by the additivies in the liquid.
I have no idea what the correct orientation is for the rad if its installed in the vertical plane. I didn't need to know this since my rad is installed horizontally. I would be interested to know though.
btw if your rad has the built in res, I do know that the res section of the rad needs to be pointed upwards; but this is obvious due to the fillport on the res.
Edit: I noticed in your previous post that you said you wanted to mount the rad horizontally with the barbs pointing upwards. Why would you want to have the barbs pointing upwards?
Surely they would point downwards in to the case. If they are pointed upwards that would mean that the tubing would have a U-bend in it. i.e. the tubing would go up through the top of the case then return in a bend into the rad. This doesn't make sense and it may affect the performance of the rad and the liquid flow in the system. Oh and its not recommended that you use right angle fittings on the inlet and outlet of the rad if this is what you are considering.
